Finally took it to the water!
    Frequent Poster Miguelxj's Avatar
    Jul 2014
    Portugal
    Red face Finally took it to the water!
    Last saturday had the chance to re-test the rebuild and almost everything went smooth.
    It started just fine on the trailer and in water, but after it sat for 5 minutes, it would start but VERY rough. I could give gas but it sounded like a missing spark.
    I insisted and eventually (very difficult) the engine came back to "normal life" . I came aboard dad's boat for 2 or 3 minutes, when I started the engine, the roughness cabe back (its the beggining of the video).
    This never happened again the whole day, so it got me puzzled....
    Video (youtube): https://youtu.be/vS6wN0a8Gj8
    in case that doesnt work: http://videos.sapo.pt/YYyW7umjg1BzAkGoVR2r
    Aug 2010
    dawsonville, ga
    Re: Finally took it to the water!
    my first thought when it does that....is its on the rich side,and when its idling....it "chalks" up the plugs...and they start not to fire.....higher rpm cleans them out....so you could check plugs and adjust a little bit if needed
    "Let the good times roll"
    Jul 2014
    Portugal
    I thought about debries on the carb, that allowed fuel to keep pouring inside evend with the engine off... (Note: I have a primer installes)
    But afterwards it sat for 1 hour or so, and everything was perfect..... ? Lol.
    Enviado do meu iPhone usando o Tapatalk
    Aug 2011
    Austin, Texas, USA
    It's nice to see another ski resurrected like this one. Sometimes something strange happens with a new build like this and you can never understand why it happened. If it ran all day without a problem then just forget it ever happened.
    Riding mostly Lake Austin
    Resident Guru lamphax's Avatar
    Dec 2013
    Austin, TX
    Cool video. Looks like so much fun. Gotta love the X2
    1986 X2 750 (SXR Carbs, 650FP, #Zero flywheel, O-ring'd D head, SXR 13/18 impeller, Wet Wolf AAT, RCJS, UMI, RHAAS, chop, fill, etc.)
    1989 X2 650 (42mm Sudco, Coffmans Exhaust, Skat 16 Impeller)
    1997 Yamaha Wave Venture 760
