Honda Aquatrax frozen Water damage. Repair options?
Results 1 to 10 of 16
    Jun 2007
    Salt Water
    I just picked up a 03 Honda Aquatrax where it was not winterized properly. I rode it and came back and found the hull 1/2 full of water. I saw two locations leaking: (1) Front engine cover and (2) bottom of exhaust loop, where a freeze plug is.
    How can I repair these? Where else should I check for leaks/damage from freezing?
    PWCToday Newbie HondaMarine's Avatar
    Sep 2010
    Newfoundland , Canada
    Re: Honda Aquatrax frozen Water damage. Repair options?
    Whats the engjne oil like? Any water there?
    Jun 2007
    Salt Water
    Quote Originally Posted by HondaMarine View Post
    How do I tell if there is water in the oil?
    SE CT
    It turns white/ milkey
    R.I.P. Super Sic
    I dream skis skidoc's Avatar
    May 2012
    tampa
    Give me a call anytime.
    Jet Skis International
    Brian Brocksmith
    813-413-7544
    http://jetskisint.com
    Free Aquatrax Tech support
    https://www.facebook.com/pages/Jet-S...91943504243227
    Jun 2007
    Salt Water
    I still havent fixed my front engine cover as yet.
    I am thinking about replacing it. Do I need to pull the engine in order to replace the front cover or can it be replaced with the engine in the ski?
    2004 Honda Aquatrax R12 - LOVING fuel injection 4 stroke, no more carbs!!
    85' Kawaskai JS550 - PRISTINE condition
    2003 Suzuki GSX-R1000
    96 SeaDoo XP - Sadly missed after my family outgrew its size (2007 -- sold 2013)
    Most guys pull the engine but they say you can get it off without pulling the engine you may have to unstrap your gas tank and slide it forward.
    3m 5200 works for sealing the front cover crack. Not beautiful but it sure works if done correctly!
    MACSBOOST!!! The Honda PWC Performance Experts. www.MacsBOOST.com
    Home of the MACSBOOST Module and the Fastest Honda PWC on the planet.
    http://www.youtube.com/watch?v=yqufmQ_8bxU
    Be our friend on facebook! http://www.facebook.com/pages/MACSBO...e/233077830901
    Jun 2007
    Salt Water
    Quote Originally Posted by SuperMAC View Post
    I head that I could use JB Weld as well, but I am thinking that I want to pull it off and weld it or something. I would not want a water failure while out on the water... thoughts?
    Or maybe I could seal it and add a high flow second bilge pump as a backup. Thoughts?
    Those front covers shouldn't be that much money I've seen some for sale in the past?
