Page 2 of 13 FirstFirst 123412 ... LastLast
Results 11 to 20 of 128
Thread: First x2 build
    Frequent Poster Born2Ride's Avatar
    Jul 2014
    Parts unknown
    Re: First x2 build
    ^^^^^^^This
    Plus you will cut away all the structural support in the hood,it will be very weak if not collaps on you....
    Oct 2012
    Belgium
    Re: First x2 build
    try to have a stock look
    not too much cutting and shoping
    keep that 86 hood stock
    nice A/M parts
    I dream skis CodyAdams's Avatar
    Apr 2014
    Lodi, Ca
    Re: First x2 build
    please tell me that c4 chamber is modified, go look at mine on my build thread, besides that nice parts
    849cc X2 custom build - http://www.pwctoday.com/showthread.php?t=439487
    Thanks for the help during 2015:
    IPD Graphics
    sixsixone
    Spy Optics
    PWCToday Regular Mpaz's Avatar
    Apr 2015
    Salem nh
    Re: First x2 build
    I have to trim the the lord mount on the on the factory manifold to get clearance but I didn't want to have the x2 rad dudes tube welded on. I'm using a 90 off the pipe with a 45 to aim me right out the back of the hull. I bought an in line water box to go into the deck. From what I've read and seen this will fit. I did get the rad dudes lord mounts for the x2.
    Apr 2015
    Salem nh
    Re: First x2 build
    I checked glass this morning it's solid actually came out better than I thought. I'm a little nervous now about the hood shave I was planning on doing wants in the picture for the hood with the air intake behind the bars. I was going to run a 2" pipe from the air intake towards the bottom on the hull. I might be scrapping this idea.
    Apr 2015
    Salem nh
    Re: First x2 build
    This is what I was going for on the hood
    Apr 2015
    Salem nh
    Re: First x2 build
    Do you guys think I should take a different direction? I was going for that look but it's not too late to go in a different direction
    Frequent Poster Matt742's Avatar
    Sep 2013
    Goodyear az
    Re: First x2 build
    Go for whatever you want it to look like, there is options when you're cutting the hood down for air intake. Read through the threads where guys have done these mods and take what you need from them to get r done. As far as the structure of the hood goes, do not cut any of the inner skeleton of the hood out or it will be too flimsy and you will have trouble with the hood sealing. That hump is ugly and there are PLENTY of guys who have shaved it with no air intake issues.
    resident guru lamphax's Avatar
    Dec 2013
    Austin, TX
    Re: First x2 build
    That looks cool but where the heck does air get in?
    1986 X2 750 (SXR Carbs, 650FP, #Zero flywheel, O-ring'd D head, SXR 13/18 impeller, Wet Wolf AAT, RCJS, UMI, RHAAS, chop, fill, etc.)
    1989 X2 650 (42mm Sudco, Coffmans Exhaust, Skat 16 Impeller)
    1997 Yamaha Wave Venture 760
    Sep 2013
    Goodyear az
    Re: First x2 build
    Quote Originally Posted by lamphax View Post
    See the duct that they glassed in right behind the steering..
