Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 68
    Jun 2014
    Seattle
    Re: It's not a Jetski, but it goes just the same!
    Subscribed, this is gonna be a sick mini boat!
    78 JS440
    -Ocean Pro Finned Ride Plate
    -Westcoast Intake Grate
    -SCR Ported Cylinder
    -Mariner Waterbox
    -Primer
    -SBN44
    -Quick Steer
    -Skat~Trak 16.5 SS Impeller
    PWCToday Guru kpino22's Avatar
    Jun 2009
    Northwoods WI
    Here are a few pics from seeming the floor back together with the hull
    1986 Kawasaki X2 - 750SP, FPP, ADA Billet Head 28cc domes, Ryski's Surfbrace, Lightened Flywheel, Dual Cooling, 46SBN, Port N' Polished,Watcon X2 Intake
    1985 Kawasaki JS550 - RRacing pipe
    1992 ULTRANAUTICS JETSTAR 1250 - 90HP Mercury Sportjet
    1994 Kawasaki 750SX - Bare Hull W/ Lots of parts to sell - Hull & Trailer fOR SALE/Potentially Free - PM for details
    1993 Bayliner Jazz - Bare Hull and Trailer - FOR SALE/Potentially Free - PM for details
    May 2015
    Rhode Island
    THANKS KP an update would be great would LOVE to see some updated pics. ONe more quick question. What is the floor plan for underneath the dash to the bow, the prior owner hacked the floor out and I'm having trouble forming it back together. Do you have any pictures of yours. Thanks again!!
    Jun 2009
    Northwoods WI
    I made made a cardboard pattern from a huge fridge box, the floor sits flush on the foam stringers in the hull. You want it to sit nice and flat, that's where you get your rigidity. The floor goes all the way to the top of the bow basically. You should be able to see where the 4" fiberglass tape bonded the old floor up to the nose unless the previous owner ground it down.
    I
    Jun 2009
    Northwoods WI
    Test fitting the floor
    Jun 2009
    Northwoods WI
    Jun 2009
    Northwoods WI
    Fitting the tank back in is a struggle, it is a very tight fit.
    Jun 2009
    Northwoods WI
    Here is the seat back in. I beveled the edge, then riveted a 2.5" aluminum plate to the back to fasten the seat back to the hull. I then mixed up epoxy with white microbaloons and filled the crack. Make sure to fasten the bottom lip of the seat to the floor first as when you cut it out it relieves a bit of tension in the hull and it like to warp up. When you epoxy the seat back in it will be rigid.
    Jun 2009
    Northwoods WI
    Cut all new seat backings out of 1/2" marine plywood then coated them with mold and mildew resistant paint.
    Jun 2009
    Northwoods WI
    Test fitting the foam on the new backers before wrapping the new upholstery.
