Thread: Bob gen2
    PWCToday Newbie slinden's Avatar
    Apr 2011
    SW FL
    Bob gen2
    Looking to sell my BOB Gen2 custom freestyle stand up
    Price: $9000
    The hull is in good shape. Normal wear and tear. To my knowledge mine is the only gen2 built with both Kawi and Yami motor mounts. Has a Yami pump. Xmetal pole and steering system.
    I am currently running a SXR based motor built by Wade Chaplin. It has 82mm pistons, freestyle porting, Ada girdled head with 190 psi, factor wet pipe that is bored to match motor, dual 46mm buckshots, VForces 2 reeds, xmetal water box and analog total loss. Rass motor mounts and Kenny keepers. Kart tank and deka battery. 20 hours on motor. Motor hits hard.
    Pump is a Solas 144 mag with 10/17 hooker prop, SBT wear ring and Xmetal trim.
    For those of you unfamilar with the freestyle world. BOB gen2 hull won world finals in 2011. (not me or this ski, same hull) http://youtu.be/GgQnrSnTjp8
    [/COLOR]
    BOB GEN2 KAWIMAHA
    KAWI 801 (BUILT BY WADE CHAPIN), FP WET PIPE, TL, ADA GIRDLED HEAD (190PSI), DUALBUCKSHOT 46MM CARBS, VFORCE 2 REEDS, XMETAL WATERBOX,
    YAMI SOLAS MAGPUMP, HOOKER 9/15, XMETAL TRIM, 85MM NOZZLE, XMETAL POLE AND STEERING
    90' SN SUPERJET STOCK 62T 701
    Apr 2011
    SW FL
    Re: Bob gen2
    Bump
    BOB GEN2 KAWIMAHA
    Apr 2011
    SW FL
    Re: Bob gen2
    Ttt
    BOB GEN2 KAWIMAHA
    Apr 2011
    SW FL
    Re: Bob gen2
    bump
    BOB GEN2 KAWIMAHA
    Apr 2011
    SW FL
    Re: Bob gen2
    Summer is coming
    BOB GEN2 KAWIMAHA
    Apr 2011
    SW FL
    Re: Bob gen2
    bump
    BOB GEN2 KAWIMAHA
    Feb 2012
    allentown PA
    Re: Bob gen2
    Text me if the ski is still available 484-597-6444
