Piston information you need to know, WISECO, PROX, WSM - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 29
    Re: Piston information you need to know, WISECO, PROX, WSM
    Don't believe any negative feedback on their pistons, I have been building engines with them for over 20 years, in that time span I have not had a single piston related failure with WSM pistons.
    I was 300SXing when 300SXing wasn't cool !
    PWCToday.com Is My Home Away From Home JHR's Avatar
    Oct 2012
    Belgium
    Quote Originally Posted by WFO Speedracer View Post
    thanks for the advice
    PWCToday.com Is My Home Away From Home mcn6's Avatar
    Apr 2006
    Oregon
    I put WSM slugs in my own engines if that tells you anything...
    Home of Newmiller Machine
    Top Dog jobrown's Avatar
    May 2009
    Little Rock, AR
    Quote Originally Posted by mcn6 View Post
    You're setting me up with wsm's right now actually! 😍😍😍😍
    Apr 2006
    Oregon
    Yes, I noticed that. I will be re-chambering your head today and your front main bearing will be thanking you for having your flywheel balanced too.
  6. #16
    Jan 2012
    Georgia
    If we are being honest...most "piston problems" are really carb problems, tuning problems, timing problems, or wore the hell out because we have been flogging it for years problems....
    Or greedy problems.... "just 10 more psi on pump gas.... just a few more degrees advance...."
  7. #17
    Most of the engines I build are for stock or near stock applications, alos if you want the most badass pistons out there Woosner is the brand you need to look at.
  8. #18
    Frequent Poster J_shamper's Avatar
    Jul 2014
    IL
    Anyone ever use the old team green trick of putting a cross hatch on the pistons?
  9. #19
    Top Dog mcycleski's Avatar
    Jul 2007
    Pa
    Its Wossner
  10. #20
    Quote Originally Posted by mcycleski View Post
    Its Wossner
    Woooooohhhhhhhhhhh doggie !
There are currently 2 users browsing this thread. (0 members and 2 guests)
