Results 11 to 20 of 24
Thread: Factory Pipe
    PWCToday.com Is My Home Away From Home Dencaddie's Avatar
    Aug 2012
    Michigan
    Re: Factory Pipe
    Kawi head pipes are the same for 650, 750, and 800 (dry pipe excluded). Install instructions show same part number.
    90 SN - Short Rockered Project Ski
    91 SN - 735 GroupK B-Piped Frankenstien
    92 X2 - HPT Ported 650 with most of the goodies
    94 WB1 - 62t JetPro Piped Weeble Wobble - sold
    95 WV - Family Ski
    charlotte,nc
    Re: Factory Pipe
    yes ninja makes a headpipe that is identical to the factory pipe head pipes.. the ninja head pipe even has the t handle water adjustment screws..
    I dream skis CodyAdams's Avatar
    Apr 2014
    Lodi, Ca
    Re: Factory Pipe
    This one? I didn't even know they made a head pipe
    http://pages.ebay.com/link/?nav=item...d=321557969662
    849cc X2 custom build - http://www.pwctoday.com/showthread.php?t=439487
    Thanks for the help during 2015:
    IPD Graphics
    sixsixone
    Spy Optics
    SE MI
    Re: Factory Pipe
    That is it. Just make sure that your manifold can be opened up large enough to match the head pipe.
    Apr 2014
    Lodi, Ca
    Re: Factory Pipe
    I will have to buy a manifold, I have the stock 4-bolt sxr manifold on the motor
    IPD Graphics
    sixsixone
    Spy Optics
    Apr 2014
    Lodi, Ca
    Re: Factory Pipe
    Turns out the one on eBay needs to be welded, there goes that one
    IPD Graphics
    sixsixone
    Spy Optics
    Top Dog Virgin Air's Avatar
    Mar 2012
    Wa.
    Re: Factory Pipe
    You can get them new from http://www.nynjapwc.com/RRRIgnitor-RRRBlasting.html
    Back to the topic of the thread: I've dealt with Cindy and FPP quite a few times since 93' and had no issues whatsoever.. Polite and cool with me!
    They even warrantied a cracked manifold for me.. FPP is GTG! Jeff
    I would like to test one of the NYNJA pipes also..
    2000 750 Sxi Pro. Factory Limited pipe, 40mm mikuni's, 13/18 SXR blade, Kommander head, Newmiller Freestyle ported #22 cylinder, lightened flywheel, aquavane & Worx ride plate, trued hull, AC handlepole. 51.8 mph
    1995 750 Sxi. stock
    1993 550 Sx. PJS intake & 15.5 skat.
    Oct 2006
    under a ton of work
    Re: Factory Pipe
    don't waste your time on nynja made in china stuff.stick to original parts like real tnt or real factory pipe.
    Top Dog Doug997's Avatar
    Feb 2010
    Las Vegas, NV.
    Re: Factory Pipe
    I got mine through Kommander Industries, but it was for a Superjet.
    2017 Kawasaki SXR 1500
    2013 Yamaha Super Jet-HighSpeed Industries Limited
    2011 Kawasaki SXR 800
    Apr 2015
    Concord
    Re: Factory Pipe
    I've had very bad experience with Factory Pipe as well. My Headpipe cracked and chipped from an obvious manufacturing defect around one of the bolts so I sent it back, waited about a month and then called and was told they won't warranty it because they're claiming one of the bolts was loose which I know for a fact is wrong because I just reassembled the ski before I took it out and always check everything before riding. So now I'm down a headpipe and $60 shipping here and back to Cali
