Cylinders???
Thread: Cylinders???
    Jan 2012
    Ames, IA
    Cylinders???
    Can 717/720 82mm Cylinders, be put on a 580/587, or 650/657 Case?
    Rich
    Top Dog mcycleski's Avatar
    Jul 2007
    Pa
    Re: Cylinders???
    No they cannot
    Jan 2012
    Ames, IA
    Re: Cylinders???
    Quote Originally Posted by mcycleski View Post
    No they cannot
    I understand the 580/587/650/657 Case may have to be opened up for the 82mm Cylinder Sleeve bigger OD, but is the Cylinder Bolt Pattern different, or something else not match up?
    Are the Head Bolt Patterns the same 580-650-720?
    Rich
    Jul 2007
    Pa
    Re: Cylinders???
    The gasket surface on the 580 is completely different you might beable to use the 720 on 650 cases I will check and see if I have 650 and 720 base gaskets to match them up
    Jul 2007
    Pa
    Re: Cylinders???
    Bolt holes don't line up ....green gasket is 720 the dark gray is 650
