dyno set up
Results 1 to 9 of 9
Thread: dyno set up
    PWCToday Newbie holmes99's Avatar
    Dec 2012
    ontario canada
    dyno set up
    i am just curious when you were dyno seadoo engines what were you using to keep the engine cool. i completely realize that i can use a hose but i was wondering at what kind of pressure. i would assume with the water injection sprayers will work differently at different pressures just like a fuel injector.
    I am just curious if you used just a straight garden hose with no regulator or a water source with a regulator on it and if that is the case what did you use for pressure.
    I am just curious cause i am going to set up a dyno for my 787 and was wondering about the water pressure??
    PWCToday.com Is My Home Away From Home kawi66's Avatar
    Jan 2003
    kawiland
    Re: dyno set up
    Quote Originally Posted by holmes99 View Post
    When I did it we just let the hose run and used msd water injection valves,it was very interesting..my mod did 135-140 hp.
    The biggest thing i learned was that usable power in jet ski's does not translate exactly from dyno to the water.we built twin pipes that made well over 150hp but had serious low end pressurizing problems off idle in the water.once they hit they hit hard with big rpm(over 8200)but they had a bad off idle stumble.
    we had some good ideas on how to correct it but i quit racing that class before we put them to use.
    good luck....
    1997 team Kawasaki carbon zxi 1100
    1997 atm lightweight zxi 1100
    Resident Guru kartracer41's Avatar
    Oct 2010
    lodi calif.
    Re: dyno set up
    Quote Originally Posted by kawi66 View Post
    good luck....
    did you do any testing with water temp,if so what temp made the most power, 120 -140????
    RGR Racing.com
    Jan 2003
    kawiland
    Re: dyno set up
    Quote Originally Posted by kartracer41 View Post
    We did not change any water temps,I was on a short time schedule every time we worked on it. He was a sled builder in Canada and took my project as a side deal..
    He did build some sleds that raced on water.
    I know that sled technology has kept moving after watercraft stopped.the average 800 skidoo was making 155 hp while I was there a few years back.
    That stock skidoo rpm band mimicked my 800 very close all the way through but just made more power everywhere.i wish I could have just put that I'm my hx!
    Riverside, CA
    6
    Re: dyno set up
    good luck....
    PJS made that mistake, Tap Water, on many of their pipes.
    The problem is the tap water only provides 4 psi of flowing water pressure, and the Sea Doo pump
    supplies 50psi of flowing water pressure to the engine. Small engines, 580's were about 40 psi.
    That difference creates more HP on the dyno and significantly less in the water. The difference
    in power would be less with dry pipes.
    A large centrifugal pump can provide 40psi, but I am not sure it will produce 50psi. You may.
    need a gear pump to properly reproduce pump pressure.
    Testing pump water pressure before and after dyno testing is a good habit, and for race tune too.
    If you are testing pipes, be sure to pressure test them before they are dyno tested.
    Bill M.
    Jan 2003
    kawiland
    Re: dyno set up
    Bill M.
    The custom pipes we built were dry. I was adding ewi to them at the end but never got it done.we tested the spec 2 pipe as a base line with water injection.He is a very good builder,he measured the ports ,timing etc and guessed the engine would do 140hp which is exactly what it did.It was a miller stage 5..I would guess 140hp is in the ball park for that motor.I believe Mel told me he never got one much over 150.(i could be wrong it was years ago)....The twin pipes did 158hp at 8250 rpm.
    It was a great learning experience even though we never completed it.
    Resident Guru mandriva's Avatar
    Sep 2009
    montreal,quebec
    Re: dyno set up
    This pipe was builded by jaws performance?(greg)
    Rossier 7250 rpm
    110 mid pipe/200 stinger
    185 psi/Head 41cc/43squish
    Solas concord 15/23
    Jan 2003
    kawiland
    Re: dyno set up
    Quote Originally Posted by mandriva View Post
    Yes it was.
    Sep 2009
    montreal,quebec
    Re: dyno set up
    Yours pipe fit on X4? Or only HX....do you have still.....Jaws performance and psi performance is best compagny who build pipe snowmobile! Do you tryed ECWI
    Rossier 7250 rpm
    Solas concord 15/23
