SXR Wetpipe and Waterbox in X2
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
    Mar 2005
    Santa Barbara, Ca.
    Here is the start I have for the PJS Supercylinder X-2. Was probably lacking with the FPP 650 pipe in there with an X2 stock waterbox so in goes a FPP Wetpipe for an SXR and an SXR waterbox.
    SE MI
    Re: SXR Wetpipe and Waterbox in X2
    Very cool, I'm sure that this pipe setup will net great results.
    PWCToday.com Is My Home Away From Home MyDixieWreckedX2's Avatar
    Jan 2012
    Olympia
    I lost 2mph on top and a ton of bottom end "seat of the pants feel" going from a blaster chamber to the SXR wet pipe on my Kommander 800, 200 lb comp, duel 48's running VP MS109.
    Next time, either post up dumb comments that mean nothing like I do, important info, or, best of all, just SHUT UP!
    Mar 2005
    Santa Barbara, Ca.
    Mine is not quite that hot ... Designed to run on 91 pump gas so maybe I won't be giving up that much. Still has to be better than the 650 pipe
    Quote Originally Posted by MyDixieWreckedX2 View Post
    Sin City USA
    Bruce the only thing I would have done different is moved that outlet to a better location, you are going to deal with pump cavitation on right hand turns, just like the stock location on the left side. I would have chosen above the bond line if I had to put it near the place you came out at. Otherwise it looks AWESOME, love the clean welding job, super nice!
    Mar 2005
    Santa Barbara, Ca.
    You know ... I thought about that before I cut it. I put it here on my 1100 conversion and really haven't had a problem with it... but then I can't ride these things like you Hot Rod guys
    Jun 2011
    Norcal
    take a picture with half of the gold hood on that bad boy
    - John Kenneth Galbraith
    Mar 2005
    Santa Barbara, Ca.
    Quote Originally Posted by cudaben View Post
    Not on Halloween ... That hood has enough voodoo on it's own.
    Aug 2007
    Stock tank fit?
    Oct 2012
    Belgium
    looking great .
