OP engine
Results 1 to 10 of 15
Thread: OP engine
    I dream skis dlscholz's Avatar
    Feb 2014
    Metro Detroit
    OP engine
    I came across a full ocean pro engine and cant seem to find much info about it. It has OP crankcase, cylinders, and head. Wondering if anyone knows anything about these engines. Thanks for any help.
    Awsome '85 550
    ​Conversion '82 550
    Freestyle '92 750
    Stock '94 xp 657x
    Stock '95 zxi 900
    Stock '05 sxr 800
    Build thread: http://www.pwctoday.com/showthread.php?t=426337
    Re: OP engine
    Pics ?
    SE MI
    Re: OP engine
    I have seen the OP heads and OP 650 cylinders but never any OP cases, do you have any pic's that you could post?
    Feb 2014
    Metro Detroit
    Re: OP engine
    it may not be a OP crankcase then. So did OP sell this engine or is it just mods? Is it worth anything?
    Awsome '85 550
    ​Conversion '82 550
    Freestyle '92 750
    Stock '94 xp 657x
    Stock '95 zxi 900
    Stock '05 sxr 800
    Re: OP engine
    OP sold bolt on aftermarket parts, the cases are stock, cylinder, head and possibly intake manifold are OP
    SE MI
    Re: OP engine
    Is it worth anything - yes. I'd replace whatever 650 engine you are running with this one for sure.
    Oct 2005
    CAN
    Re: OP engine
    Agreed. Ocean pro should reproduce some of this stuff.
    Re: OP engine
    Quote Originally Posted by Merk View Post
    He found a better market, making heads for flathead Fords
    PWCToday.com Is My Home Away From Home jdpilot's Avatar
    Sep 2006
    New Hampshire
    Re: OP engine
    There were 2 different op cylinders. One with bridged exhaust, one with standard exhaust. Which one is this? I have a bridged.
    If its bridged, piston skirts need oil holes drilled...
    Prospect Mountain Powersports
    Altitude; 653
    Limited 87 650SX- 43.6
    Limited 93 X2- 45.1
    Limited 87 hull/86 internals X2- 43.7
    92 WR3- 37.0
    93 WR3 w/Shuttlecraft JetSport
    94 WB1- Limited
    09 superjet- stock 1 owner
    88 WetJet 432- stock 1 owner
    87 X2- stock 1 owner
    82 js440- stock 1 owner
    92 js440- stock 1 owner
    85 js550- stock 1 owner
    85 js440 super stock- Expert Womens Class
    85 js440- super stock- Region 8 Novice
    Oct 2005
    CAN
    Re: OP engine
    They made some good stuff back in the day. I still have all my OP catalogs from 88-92
