Results 11 to 19 of 19
    Re: Rad Dudes Conversion Plate.
    Maybe you should try contacting them using another email account ?
    PWCToday Newbie Manitobaman's Avatar
    Mar 2014
    Canada
    Thanks wfo speedracer for reply, plate is at welder getting cut and welded, no big deal, water under the bridge.
    Top Dog air blair's Avatar
    Feb 2009
    lakeport, Mi
    I baught a handlepole bracket from them and over the phone they gave me one dimension, when i got it it was a half inch off that dimension. Too big. They refunded my whole purchase and shipping so that part worked
    its your world im just livin in it. livin it. Go big or go small just have fun and be safe
    I dream skis smitty1's Avatar
    Jan 2013
    San Angelo, Texas
    Quote Originally Posted by jdpilot View Post
    That's kinda DOUCHEBAGGED up !! No reply after you gave them $ GOOD Tech support eeehhhh..??
    Jan 2013
    San Angelo, Texas
    Maybe you should drive out there Knock on door ??
    I dream skis chev-hell's Avatar
    Ft.Worth, Texas
    I had the exact same experience with the same bed-plate.... the 800 motor wouldn't bolt to the plate because it wasn't cut deep enough for the stator cover.... had to cut off about 1/2" in front, once that was done, I mounted it and found it to be 40mm away from driveshaft. so, I took it to a machine shop and had the mounting holes drilled back 40mm, and then another 40mm cut off the front again so the motor would mount.. I also had to oblong 1 mount hole that was off about 8-10mm...... Also no hard feelings, but an expensive plate to begin with and another $80 in machine work.. now that it's mounted, I will say it's the correct height which would have been hell to correct if it wasn't... This was an 800 in a trinity hull set-up for yamaha power (they said it would work...)
    Krenn Power Sports
    707 North Fwy. Ste. 107
    Ft.Worth,Tx 76102
    Krennpowersports@gmail.com
    Aug 2014
    Chevy,
    Do you realize that when you make major changes to some one elses copywritten items, that you can apply for your own copywrite ? Thats why sheet needs to be right when your selling it. You could lose your pattened to a improved design.
    I dream skis dbloxx2's Avatar
    Oct 2012
    fountain hills az
    Man I wish I saw this before I bought my "rad" dudes conversion plate I'm also currently in the same boat I bought mine a little over a month ago when I finally got time to go up to my motor builders home to start fitting my 1100 in my x2 the bed plate didn't fit the bolt holes I sent them an email about how the return process works and and if im really going to be charged the 15% restock fee since it wasnt my fault im sending back the item all I got for a response was "clearly we can not refund u with out our merchandise back" and since then I've sent them 2 emails since the tracking said it landed at there address and guess what no response back since the last one before I shipped part back to the rad dudes so at this point I don't know what to do other than try a few more emails and if no response back then I'll be forced to see what I can do threw pp since I payed threw that but not sure if anything can be done now
    '86 Kawasaki x2- still deciding what to do with it
    '88 Kawasaki x2 - waiting to become epic
    '94 Kawasaki 550sx-750 conversion
    '94 Kawasaki 750ss - pile of $h*t at the moment
    '97 Kawasaki 1100 stx - wifes whip
    Instead of making a remark and restarting a PWCT war I will just post this.
