Project HX - Page 2
Page 2 of 55 FirstFirst 12341252 ... LastLast
Results 11 to 20 of 549
Thread: Project HX
    I dream skis HX RACER's Avatar
    Feb 2010
    PSL Florida
    Re: Project HX
    I went with a 12 vein set back 140 Mag pump. Hopefully testing soon.
    Top Dog RIDEH2O's Avatar
    Jun 2011
    nevada
    Re: Project HX
    Didnt do alot this weekend....cleaned hull and epoxied inside. Parts are coming next week, so while its light weight, Ill work on the bottom of the hull.
    I was also a little distracted by these two.......Fall is in the air here in Reno
    Jun 2011
    nevada
    Re: Project HX
    These have to be the cleanest carbs Ive ever seen come of a used ski !!
    I still changed all the bolts to ss socket heads.
    Jul 2011
    NJ
    Re: Project HX
    Wow, this things gonna be propper...nice work so far !!
    Jun 2011
    nevada
    Re: Project HX
    Quote Originally Posted by tturbonegro View Post
    Thanks. I wish I could make things happen faster, but I have a business to run during normal hours. I only get to play with the HX after work. And on weekends if im home??
    Jun 2011
    nevada
    Re: Project HX
    I need help from the experts.......Im still on the fence about the pump situation. Keep the 140 or go 155? The 155 is alot of work and I dont know how much of a gain it is? And can someone school me on the effect of different size nozzles? Maybe put one on the 140?? Im just not sure what to do......
    Anyone?
    PWCToday Regular Red94yj's Avatar
    Feb 2014
    Alabama
    Re: Project HX
    I can't help with pump info, but your build potential is sweet. I like your fab work on the stand/roll around cart.
    The work your putting in is quality.
    Keep up the good work.
    I'm following along. Can't wait to see how this turns out.
    89 x2
    93 x2
    Feb 2010
    PSL Florida
    Re: Project HX
    If you stay with a 140 pump then go with a 6 or 12 vein mag pump
    Jun 2011
    nevada
    Re: Project HX
    Quote Originally Posted by HX RACER View Post
    Did you test it yet? Those pumps are spendy, huh?
    Jun 2011
    nevada
    Re: Project HX
    So, I fabricated a little piece today. I like the Rad Dudes big oil pump block off plate, but I still wanted the water cooled stator. Even though the HX is much lighter than the big ol' Kawi the motor came out of, I still like the Idea of a cooler stator..
    I removed th big C clip that holds in the oil pump shaft and bearing, pressed out the bearing, replaced the bearing with this same size aluminum plug I made on the lathe, put the C clip back in. I used a little rtv for extra sealant.
    I probably didnt need to do this but the only thing between the water cooling and the stator is that goofy shaped o-ring, and the oil pump bearing was toast, anyways. I feel better now! Besides, it fun to play on a real lathe once in a while.....
