Build thread! 750 jetmate wakeskate machine - Page 3
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 63
    Resident Guru Taynton's Avatar
    May 2009
    Kelowna BC
    Re: Build thread! 750 jetmate wakeskate machine
    Thanks for the picture! I hear what you are saying about the gunwales! I will be looking for a solution.
    WFO. ordered the carbs from matt jones. may need some jetting help with them when I get them, also do you know where is a good place to get rebuild kits?
    Now just waiting for the blockoff plates. and the carbs I hope they get here soon i have a houseboat trip this weekend I really wanted to bring the jetmate.
    anyone know how bad it is to run this motor with the throttle arm leaking? I know it ran before removal and if its a bushing then its been this way for a while.
    1989 JS 550__________Jet Sport scoop intake
    Factory Half pipe______Jet Sport skegged rideplate
    Skat-Trak 15.5* _______JRE quicksteer plate
    bored nozzle__________JRE -2'' sub plate
    honed pump__________JRE adjustable bars (0*)
    OP steering nozzle_____VORTEX F/A
    OP reduction nozzle____BCW intake,
    SBN44 carb__________Jet Sport head
    OP alu bedplate______Jet works FCV
    May 2009
    Kelowna BC
    ttt
    May 2009
    Kelowna BC
    come on guys! what do you think about running it with the leaky carb??
    also got my JRE blockoff plates! installing them now going to water test tomorrow!!
    also got the JRE sub plate for my 550! handle pole will be - 3" now sweet!
    May 2009
    Kelowna BC
    Ooohh pretty! Too bad no one will see it! Anyway motor is back in and hooked up going to water test it tomorow. At the risk of sounding like a broken record does anyone have any input on my carb situation?
    PWCToday Newbie fasterblaster1's Avatar
    Feb 2013
    Bonita Springs
    I wouldnt run a leaky carb. That could cause a lean condition and toast a motor. Buy a rack of carbs. I would rather buy a rack of carbs then rebuild a motor
    May 2009
    Kelowna BC
    Thanks for the reply I was thinking the same thing however i was also thinking the throttle shaft was high enough in the intake that it shouldnt mess with the intake charge/fuel mixture. I will replace both carbs. I have two on order from matt jones but it will be a while before i can install them I have a houseboat trip this weekend. just wondering if anyone has ran like this or am I off on the assumption that it wont affect the fuel mixture
    May 2009
    Kelowna BC
    *update*
    Water tested. It floats! one carb not getting fuel. waiting on a set of carbs from matt jones and a couple rebuild kits. getting so close....
    May 2009
    Kelowna BC
    Update.
    Got the carbs. Rebuilt them. Installed them
    Jetmate starts pretty easy and idles high. Anyone know the stock settings for the small pin 750?
    On another note after leaving it for a few days the bottom end flooded so I think fuel is leaking past the carbs. Anyone know what would cause this? Just hoping it has nothing to do with the rebuild I did. Any Imput helps thanks guys
  9. #29
    PWCToday.com Is My Home Away From Home tonyvisone's Avatar
    May 2010
    New Hamshire
    subscribed.
    can u post pics and details of what electronics u used, battery placement, etc....
    87 JS550- WC reed cyl.. 51 mph
    89 Jet Mate 750
    91 chicken 750 big pin in progress
    93 B1 1100
    93 750sx
    94 750sx
    94 B1 760
    97 Doo GTX bought new
  10. #30
    May 2009
    Kelowna BC
    I will take some pics tomorow. My plan was to run two battery's. One in the engine compatriot for the motor where the old oil tank was and another in the original battery location. This may change when I fit up the factory pipe
