Build thread! 750 jetmate wakeskate machine - Page 2
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 63
    Dec 2006
    Mesa AZ
    Re: Build thread! 750 jetmate wakeskate machine
    Dual SXR carbs!
    Quote Originally Posted by Taynton View Post
    Update:
    Ok so I finally got the ebox mounted and the throttle cable bracket modified. Battery is hooked and ready to fire! After some cranking and some manual priming it started up and ran beautifully
    once I shut it off I started to see fuel pooling below the motor. Upon closer inspection it was coming out of the crankcase drain valve as well as the throttle arm from the carb. So I pulled the motor and remove the valve I am now waiting for one to come in the mail I am hoping the carb leak will work itself out or something (probably wishful thinking) but i really don't want to replace the carbs.
    If I need to what should I replace the carbs with? Currently has the stock keihin dual carbs
    There is a process where you can flip the stock plate over and use it as a blockoff or you can use a pipe tap and tap the holes , then use pipe plugs and 1211 to plug the holes up .
    Resident Guru Taynton's Avatar
    May 2009
    Kelowna BC
    Thanks WTO I think I'll just order like 3 so I can eliminate it from all my 650s and 750s and never deal with this again
    1989 JS 550__________Jet Sport scoop intake
    Factory Half pipe______Jet Sport skegged rideplate
    Skat-Trak 15.5* _______JRE quicksteer plate
    bored nozzle__________JRE -2'' sub plate
    honed pump__________JRE adjustable bars (0*)
    OP steering nozzle_____VORTEX F/A
    OP reduction nozzle____BCW intake,
    SBN44 carb__________Jet Sport head
    OP alu bedplate______Jet works FCV
    Not a bad idea
    May 2009
    Kelowna BC
    ok guys the blockoff is ordered! also picked up a JRE shortened sub plate!
    Next issue is the carb leak.
    Will I lean out if I run it this way? (leaking gas from the throttle shaft)
    I keep hearing about SXR carbs. what are the benefits? ( fuel economy is a factor for me)
    would I need a different intake? Are there other options?
    Dec 2006
    Mesa AZ
    SXR carbs are just dual 40mm mikuni SBN's. Pretty easy to come by as far as dual sbn's go. I use a factory big pin intake.
    BTW Matt Jones has a smoking deal on a set of three jet Kehins !
    May 2009
    Kelowna BC
    Saw those. already pm'ed him lol thanks for the heads up
    PWCToday Newbie fasterblaster1's Avatar
    Feb 2013
    Bonita Springs
    Feb 2013
    Bonita Springs
    My brother and I built this tower for my 750 Wetmate. We found that if you install a tower that mounts to the top of the gunwhale, the fiberglass is to thin and its tough to find a spot to through bolt that instead of lag bolting it. We used the stock grab handle spots and built this one to be stronger than Blowsions and be able to pull a wakeskate.
