JS 440 has water in engine compartment
Results 1 to 10 of 14
    PWCToday Newbie Vasilis 440's Avatar
    Greece
    Hello everyone. I have a 440 which works great, but after every ride it has some water in the bottom of the engine compartment, about 1-2 inches deep. Is this normal?
    I dream skis dlscholz's Avatar
    Feb 2014
    Metro Detroit
    Re: JS 440 has water in engine compartment
    No not normal it may be an exhaust leak
    Awsome '85 550
    ​Conversion '82 550
    Freestyle '92 750
    Stock '94 xp 657x
    Stock '95 zxi 900
    Stock '05 sxr 800
    Build thread: http://www.pwctoday.com/showthread.php?t=426337
    Greece
    The tube after the waterbox had a cut and i replaced it but it still gathers water. I can't find any other leakage. When i run the ski in the yard with the water hose i don't see anything suspicious. Only after riding it in the sea there is water in it. Is it impossible that the water gets in the engine compartment from the vent on the hood?
    Resident Guru Durhamgoat's Avatar
    Jun 2008
    Jasper IN
    It can get in from the hood, check your hood seal. The ski has a siphon bilge pump that sucks this small amount of water out using pump vacuum. You should check to see if it is intact. I always have a little water in my hulls after riding, not several inches though.
    440 JS Stock
    440 PJS ski with ported cylinders, shaved head, pjs exhaust, pjs pump and exit nozzle, etc.
    550-750 Build...http://www.pwctoday.com/showthread.php?t=397055
    Aug 2010
    Australia
    all old skis get some water intrusion from varios places ,hood seals , pole grommets (where the cables go), vents , etc , if you are real concerned fit an electric bilge pump , trying to track leaks in old skis is near impossible ,so long as all your electrics are sealed ,it should not be an issue ...
    modded X2 650
    900 powered custom 650 sx .
    PWCToday Newbie Flaco79's Avatar
    Jul 2014
    Texas
    How many hours of riding does it take to fill with that much water, my 97GTI fills with water also but take all day and normally it fills in choppy water smooth bays or bayous don't seem to take on as much water so it's probably coming in from aground the seat and hood seals
    Greece
    Well, maybe I overstated a little bit about the depth of the water. It is always below the filter of the bilge, so I guess it 's not anything abnormal. The only problem is that the water splashes and soaks everything in there, causing rust on some places of the engine. Any idea of solving this?
    Jul 2014
    Texas
    Try checking the bailers and hoses these get clogged sometimes
    Jul 2014
    Texas
    I also like to keep my engine and hoses, wires covered in silicone spray to avoid the rust
    Aug 2011
    Austin, Texas, USA
    Unless almost everything is sealed very well and you ride very cautiously in flat water you will get water inside. It certainly sounds like yours is normal. Leave the hood propped open when the ski is not in use and spray with some sort of lubricant to cut down on the rust. If you ride in salt water then wash down and rinse the cooling system and engine compartment.
    Riding mostly Lake Austin
