750sx msd ignition question
Results 1 to 10 of 15
    Frequent Poster kpino22's Avatar
    Jun 2009
    Northwoods WI
    What does it take to get a msd pro-digital ignition up and running on a new 750sp motor. I found brand new for cheap, but I believe it is the brain unit only. Does it work with the rest of the stock ignition, or do I need other components? And if so, what do I need?
    -KP
    Frequent Poster Magyar68's Avatar
    Aug 2010
    Lewisville, Texas
    Re: 750sx msd ignition question
    You at least need a Trigger plate, Pickup, 2 Coils (one for each cylinder) and Flywheel.
    http://www.bullettracing.com/cartelec42380.php
    http://www.jetskisolutions.com/c13_m...m_systems.html
    2010 EME Q8 Stalker
    2000 Kawasaki SXI Pro
    90 SuperJet
    Jun 2009
    Northwoods WI
    Does it have to be used for total loss? Is there anyway to use it with a lightened charging flywheel
    1986 Kawasaki X2 - 750SP, FPP, ADA Billet Head 28cc domes, Ryski's Surfbrace, Lightened Flywheel, Dual Cooling, 46SBN, Port N' Polished,Watcon X2 Intake
    1985 Kawasaki JS550 - RRacing pipe, PJS nozzle
    1992 ULTRANAUTICS JETSTAR 1250 - 90HP Mercury Sportjet
    1994 Kawasaki 750SX - Bare Hull W/ Lots of parts to sell -
    1993 Bayliner Jazz - **NEXT PROJECT** - Soon to have a Merc 175XR2 Sportjet!
    Aug 2010
    Lewisville, Texas
    I know the Enhancer Works great with lightened Flywheel. I do not know for sure if there is an application of this Digital Ignition that works with the Analog Electronics of the SX/SXi product line.
    2010 EME Q8 Stalker
    90 SuperJet
    Jun 2009
    Northwoods WI
    Looks like I want the enhancer then. I don't want to have to buy another flywheel, etc.
    Frequent Poster J_shamper's Avatar
    Jul 2014
    IL
    The pro digital on my 750 sx uses one pickup coil at $60-80 for the coil not to mention the mounting plate, flywheel and mod to the stator cover.
    Jun 2009
    Northwoods WI
    J_shamper could you pm me a picture of your set up by chance?
    Jul 2014
    IL
    The pickup coil sits close to the bendix gear. You have to drill and tap the mounting holes for timing plate and the hole through the block for the trigger wires. Everything is cast just never tapped out.
    Jun 2009
    Northwoods WI
    Ohk. Where do you mount the. Ebox then? Is it easy to mount the timing plate?
    Jul 2014
    IL
    You can mount it where the original was, just have to get a little creative. Time plate is easy if you're comfortable drilling and tapping holes.
