Dual 44mm Carbs on Superjet
Results 1 to 10 of 16
    Resident Guru Doug997's Avatar
    Feb 2010
    Las Vegas, NV.
    I wanted to ask you about switching the stock 38's for 44's. I understand that there's a need for a second pulse line to be added. Is this something that GroupK could do?
    2017 Kawasaki SXR 1500
    2019 Suzuki DRZ400SM
    2020 Yamaha YZ250
    I dream skis Allistah's Avatar
    Mar 2004
    Tracy, CA
    Re: Dual 44mm Carbs on Superjet
    What mods do you have on that engine?
    Sep 2008
    City of Blasters
    You can drill cases yourself and install a pulse fitting. I have also use a "Y" before with only one pulse fitting.
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Traci Cottle Photography
    Greg Barnhart Photography
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
    Feb 2010
    Las Vegas, NV.
    Quote Originally Posted by Allistah View Post
    No mods yet. My plan is to buy a Factory Pipe, have the head milled a little bit so I can still run pump gas, and then add the carbs last.
    2020 Yamaha YZ250
    Feb 2010
    Las Vegas, NV.
    Quote Originally Posted by Yamabooeey View Post
    Hey Norm- I would love to do it myself but I do not have the garage to do this work in. I'm a little "handicapped" when it comes to garage space here in North Carolina. I have most of my tools in Las Vegas.
    2020 Yamaha YZ250
    Mar 2004
    Tracy, CA
    From what I remember, Harry said that there was very little to no difference in switching from dual 38s to dual 44s. You might actually lose some bottom end by doing that.
    I have a 701 Hammer kit from GroupK and I run the recommended single 44. The thing completely rips and I regularly pull away from stock 800 Skis.
    To effectively use those 44s, you would have to have some aggressive porting and I'm still not sure it would be worth it. You may want to read all the docs on GroupK's site on all of the SuperJet testing they've done. It will save you a lot of time and money in the long run.
    Here is a tip I learned: Follow their recipes to the letter. You'll be really happy with the results. I love my Hammer kit - I'm not touching it - and the stock single 44 on it.
    Sent from my iPad using Tapatalk HD
    Sep 2008
    City of Blasters
    Quote Originally Posted by Doug997 View Post
    You can do this if you have a reed spacer. Or someone with a drill press can drill it out for you.
    http://www.adaracing.com/personal-wa...degree/31-1303
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
    Tech Guru Resident Guru
    Feb 2002
    Fort Mohave, AZ
    Many thanks to those that chined in before I got to the post. In general, we have gotten great results from the dual 44s (from the 760/Blaster2) on the 845 big bores. However on all the smaller bore setups (81mm-86mm pistons) the modified dual 38s have pretty consistantly given the best combination of acceleration and fuel range.
    If you do fit the Blaster2 dual 44 carbs, you will need to put in the second pulse line. We have seen guys that have tried to drive both fuel pumps with a single pulse line and a "Y" fitting .... but such a setup will struggle to drive both pumps effectively at higher rpms.... we advise against it. We also advise against reed spacers on any SuperJet setup.
    Respectfully, Harry Klemm
    www.groupk.com
    Mar 2004
    Tracy, CA
    Looks like I was on the right track with my post. Looks like you'd be better off sticking with the 38s.
    Feb 2010
    Las Vegas, NV.
    Thanks for your advise.
    2020 Yamaha YZ250
