Yamaha VX 110 security remote issue! - Page 2
Results 11 to 20 of 50
    Frequent Poster cjburt's Avatar
    Mar 2005
    Enterprise, MS
    Re: Yamaha VX 110 security remote issue!
    Did all that, good connections everywhere. Also what is the deal with it timing out after a few seconds and then not coming back until box is unplugged. Seems to me like something in the ecm is telling it something is wrong and won't let it run, especially since when I do crank it the check engine and warning lights come on.
    I dream skis Ernest T's Avatar
    Sep 2009
    Woods on the left past Mayberry
    Can you keep it on long enough to check codes? So is the engine actually starting? How long will it run?
    Mar 2005
    Enterprise, MS
    I just found out about the codes, I'm at work now but I'll try tonight and see what it says. It will run as long as I want it to, but if I turn it off and don't touch anything for few seconds it times out and won't come back until I unplug again.
    Mar 2005
    Enterprise, MS
    Oki just ran the codes and I received a 47(Slant detection switch malfunction). What the Heck is that?
    Mar 2005
    Enterprise, MS
    Ok found the slant detection switch on the side of the electric box. What does it do
    Mar 2005
    Enterprise, MS
    Nevermind, figured out what that was. Exactly what it says, detects slants. I had it laying on its side. Turned it right side up and it cleared. I have no codes now. Just no negative still.
    Mar 2005
    Enterprise, MS
    I give up, please help. It makes no sense.
    I have to plug in the security box without a ground to starter relay or it won't do anything. Then I have to connect a ground to relay and it will start. It will start a hundred times if I want it to but once I kill it and let it set for 5 seconds after the display goes out, it's over. Nothing again until I unplug.
    I know you guys are way smarter than me, please tell me what's wrong with this thing.
    Dec 2007
    st pete beach florida
    Weired problem that i have never seen, so hard to help
    I would try another main relay located on top if the electric box.
    I don't know where the ground to the starter relay is connected to, never had to mess with it but may be found by tracking the wire , wiring diagram will help too.
    The ecm has nothing to do with starting system
    Mar 2005
    Enterprise, MS
    Yeah it's weird alright. I have tried 3 good relays and of course I have tested them according to manual. I have studied this wiring diagram until I'm cross eyed and have looked at everything I can possibly look at. There must be a wire shorted or something. I may actually just pull engine again and carefully look at everything.
    Mar 2005
    Enterprise, MS
    So Frenchy, since you said the ecm has nothing to do with starting and I'm not getting a ecm code is it safe to say the ecm is ok and I don't need to order one? I was fixing to grab one off ebay.
