i shrunk my SX 650 - Page 3
Page 3 of 21 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 201
    Aug 2010
    Australia
    Re: i shrunk my SX 650
    Quote Originally Posted by 550/440 View Post
    That is a beauty! Nice work, I love the lines. I'm surprised you didn't tubby it or widen it, but to each his own. It should be a fun ride!
    i did do a rough draft model up of some that can be glued on with uathane , but decided against (ended up in the to much time consuming pile for the time being ) " so " tubbies could be a posibility later down the track ,if need be , since this will be a surf and freestyle ski " i dont think " it will be needing the stability at speed that tubbies give ,although they could be an advantage when wave jumping in the surf so i will see how the ride isfirst , and go from there with that option
    modded X2 650
    900 powered custom 650 sx .
    PWCToday.com Is My Home Away From Home jetskijockey's Avatar
    Dec 2007
    Eau Claire, WI
    My oh my Hyosung. That is nice work!
    Aug 2010
    Australia
    Quote Originally Posted by jetskijockey View Post
    thank you....
    modded X2 650
    PWCToday.com Is My Home Away From Home 550/440's Avatar
    Jan 2009
    Arizona!!!
    Did you make a mold for that nose piece?
    "needs carb work" is a classic excuse for I don't know wtf is wrong!
    DASA powered 2009 EME Q8, 2001 XLT rescue boat, 1100 WB1 in the works.
    Big thanks to Newmiller Machine in Oregon for the great work! (Mcn6 on PWCtoday)
    Aug 2010
    Australia
    yes i have the mould for the front , i also have a mould for the rear fills , with the rear fills i pull parts from the moulds , blend them on just like the front ,i just need to drill a hole in the underside so as i can refill the cavitys with expanding foam ....
    modded X2 650
    PWCToday.com Is My Home Away From Home Ragged Edge Racing's Avatar
    Dec 2004
    At D River
    The real question is what kind of power and pump will be put in this? DASA? Mag pump? At a min it has to have a 750 motor and pump...
    Aug 2010
    Australia
    Quote Originally Posted by Ragged Edge Racing View Post
    i have a proven freestyle build 650 set up i am very happy with that i will be using in this hull "" yes a 650 """ ,all parts ,steering ,engine ,electrics ,pump, etc will be cannablized from my other SX ,since that was an exeptional surf /freestyle combo i dont think building a new set up will be necessery ....
    modded X2 650
    Aug 2010
    Australia
    it was sad to see the trusted Sx come to peices today ,,""" anyways for a good cause "" found a few odds and ends that need some attention before fittment of some parts to the new hull """ like a stop button wire that fell apart when i pulled the plug connector """ soooo the old hull is now stripped and some assembly was done today .... also i took some pics of the length comparisment ....
    modded X2 650
  9. #29
    Aug 2010
    Australia
    modded X2 650
  10. #30
    Aug 2010
    Australia
    modded X2 650
