i shrunk my SX 650
Page 1 of 21 12311 ... LastLast
Results 1 to 10 of 203
    Aug 2010
    Australia
    i shrunk my SX 650
    """ OK""" so i bought a hull to shrink , i aqiured and recycled a realitivly mint 650 sx hull that a guy wanted 50 bucks for, he used the runnning gear from into a 550 , the rear exhaust 91 hull i dragged home was a bit dirty, but in above average condition,'''''perfect for my plans ''' to make a custom desighn , lightend , reshaped , hull out of ... so here is before and after rather than clutter up a thread with SSSSOOOOOOO many pics , i have many of the in betweens , suttle changes + moulds of all the custom parts ,
    modded X2 650
    900 powered custom 650 sx .
    Aug 2010
    Australia
    Re: i shrunk my SX 650
    Quote Originally Posted by hyosung View Post
    modded X2 650
    Aug 2010
    Australia
    modded X2 650
    Aug 2010
    Australia
    modded X2 650
    Aug 2010
    Australia
    i will be canniblizing my freestyle SX 650 for most of the parts ,engine pump , steering , etc ...
    modded X2 650
    Resident Guru bird's Avatar
    Jul 2012
    La Crosse right on the RIVER
    Looking clean, any reason you didn't do footholds?
    Third Coast Freeride - Midwest Wave Warriors
    Wooka Wooka Wookay. Let's Fing Rage!
    Aug 2010
    Australia
    i have rode skis with foot holds and found them more hinderance than help personaly i find good grip shoes and mat combination is a better option to foot holds + the narrow deep tray in the 650SX ski is comfortable for my ride style ( i may mount some straps in the future ) , i have moulded a raised kicker to mount in the rear of the tray once the pump is in place ,
    modded X2 650
    What length did you end up with, I am thinking it will handle similar to a 300SX
    Oct 2013
    funky town
    Huh, you can't even see the duct tape. Nice!
    I'm only here to make you mad
    Aug 2010
    Australia
    190cm on the underside toe to tip ,bond line is 2.5 cm longer as i angled the rear,should be real loose and drifty as i radiusd all the sharps on the underside & changed a few lines , also big benifit on one of thes hulls i saved 28 kg in weight by chopping out un neccessery cr&p , was not so good ""nah mate"" i used masking tape as it was eaiser to get the bog to stick to ....
    modded X2 650
