impeller shaft bearing replacement
trying to replace the impeller shaft bearings on my Kawasaki 1991 440. anybody have experience with this? i have the impeller shaft removed... do i have to press off old bearings? press on new bearings? thanks.
Re: impeller shaft bearing replacement
I ordered replacement bearings from eBay but looks like I'm Gonna find a shop to remove and install the bearings on the impeller shaft. Don't wanna screw it up.
Update:
Lawhorn's Machine Shop in Monks Corner hooked me up and pressed the new bearings onto the impeller shaft. I'll rebuild the 440 this week and hopefully get it in the water
- You may not post replies
- You may not edit your posts
Forum Rules
