A special built 750 pro - Page 3
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 67
    Frequent Poster 550sxguy's Avatar
    Aug 2013
    Schaumburg il
    Re: A special built 750 pro
    Okay but just to let you know I'm no expert when it comes to fiberglassing and resins and stuff. This is just the way I feel comfortable doing it.
    98 kawasaki 750 sxi pro, 701 61x motor conversion, rn superjet handle pole conversion.
    91 kawasaki 550sx reed motor skat 16 prop.
    94 seadoo spi girlfriends ski has a 580 spx motor with big bore kit an dual 44mm carbs.
    Aug 2013
    Schaumburg il
    Didn't get anything done to the ski this weekend. The weather was finally good enough to take my other skis out. Had a blast on lake lemon.
    Aug 2013
    Schaumburg il
    My brother finish welding my trailer to convert it to a three place trailer. I was test fitting the 750 to make sure it fit.
    Got her all tore down. I'm going to take it to a friends to power was the hull and clean it then start sanding and I hope to get some of the carbon fiber laid down this weekend.
    PWCToday.com Is My Home Away From Home afraz1er's Avatar
    Oct 2007
    BOISE
    You should have went with a stoltz bow stop instead if the metal to save against beating up your paint and fiberglass.
    Sent from my XT907 using Tapatalk
    - (project) 99 fixed steer super jet - 144 pump, 10/17 impeller, protec trim, R&D grate, 61x/61x 701, destroyer tubbies
    - 94 WB1, 760, superjet FP limited chamber
    - 00 24/7 carbon - solas 144 mag pump, raider trim, 9/15 impeller, jet dynamics grate, 61x/61x ported 718, FP limited chamber, KP pole, KP pole bracket
    - (project) 89 x2 - 650 pump with stuffer, 9/15 impeller, OP nozzles, 62t/61x TNT ported 753, single 46sbn, blowsion adapter, superjet FP mod chamber, ATP waterbox
    Oct 2007
    BOISE
    Aug 2013
    Schaumburg il
    I'm going to glue some padding to it. I have to do a couple of adjustments.
    Aug 2013
    Schaumburg il
    Plus up here in Chicago they would break those and have my skis in no time.
    Aug 2013
    Schaumburg il
    Got the rest of the decals removed and washed it inside and out. Also have it upside down right now filling in the pits and dips so when the carbon fiber is down it won't fallow the dips.
    Got the handle pole apart cause the guy I bought it from had cut it down two inches. But when he put it together. One he used bondo to glue it. That's a no no in my book. And two mounted it ****ed to the right a inch and a half. So I layed two layers of carbon fiber the the fiberglass area for strength. Got JB weld made for fiberglass and metal to glue it back together. And I didn't get a pic but drilled and put new rivets.
    I would of got more pictures but as I was working on the ski I was also smoking my home made jerky. And well seems I had a coon friend trying to get to it and when I tried to run it off it took shelter in my project Camaro in the garage. I took me a hour to get him out. Suburban coons are fearless. Lol
  9. #29
    I dream skis erg69's Avatar
    Mar 2011
    Shawnee KS
    Looks good. Both the ski and the meat. I make my own deer jerky in the winter months, cabelas has great rub.
    I feel sorry for people who don't drink.....when they wake up in the morning, that's the best they will feel all day.
  10. #30
    Aug 2013
    Schaumburg il
    I try to come up with different marinades. So far everyone loves my franks buffalo wing flavored and that one in the pic was my bourbon BBQ flavor.
