'92 750sx - Page 7
Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 95
Thread: '92 750sx
  1. #61
    Cypress, TX
    Re: '92 750sx
    From https://www.bottompaintstore.com/dur...n-p-10556.html
    "● SMC – can be used for cosmetic repairs. For structural repairs prone to high degrees of stress and flexibility, use an SMC repair product."
  2. #62
    Frequent Poster oldguy750's Avatar
    Jun 2013
    SoCal
    Re: '92 750sx
    "● SMC can be used for cosmetic repairs. For structural repairs prone to high degrees of stress and flexibility, use an SMC repair product."
    Thanks for the info. I used it for cosmetic use over the cabosil, and carbon fiber. There is a lot fiberglass reinforcement on the inside of the rocker.
  3. #63
    charlotte,nc
    Re: '92 750sx
    duraglass is great stuff. its waterproof, kevlar reinforced. fairly easy to sand, and adheres to smc. no need to grind it out for cabosil. cabosil is very hard to sand. if you are glassing over the body work then the duraglass should be fine. ive always used it as a finishing type filler then sealed it up with paint. ive glassed over it without issues. you should be fine to glass over the duraglass.
    bondo brand definitely wouldnt use on smc or in marine applications.
  4. #64
    Jun 2013
    SoCal
    Re: '92 750sx
    ^^^Thank you
    This is my first time working with carbon fiber so I used it in a spot that will be painted over.
    Filled in the dash
    Smoothed out the bond line with cabosil
    Filled in the tray hump/dip
    Blended the inside of the rocker to hull with cabosil and 407
  5. #65
    Jun 2013
    SoCal
    Re: '92 750sx
  6. #66
    Dec 2009
    Buffalo
    Re: '92 750sx
    Very nice!
  7. #67
    Jun 2013
    SoCal
    Re: '92 750sx
    Base for right side sponson done
    Pattern made for left side sponson. Left side base also done.
    Both sides of hull cf reinforced
    UFO's glassed in
    Bilge sprayed
    I got a little thin in some spots on the rocker so I added one layer of cf. It overlaps where the rocker meets the hull. Far from perfect but for my first time and for being on the bottom of the ski its's perfect enough
  8. #68
    Jul 2015
    Huntsville AL
    Re: '92 750sx
    Quote Originally Posted by oldguy750 View Post
    UFO's glassed in
    Bilge sprayed
    Ayyy if you're gonna print photos of my ski, they had best be full-color prints, you SOB!!!
    Awesome job so far! I wish you were around to help me fix the hole in my ski. Willing to make more sponsons?
  9. #69
    Jun 2013
    SoCal
    Re: '92 750sx
    Haha. Sorry my work only lets us print in black and white. I love your build. Trying to stay focused on this project, get it painted and droppped off at Jettrim.
  10. #70
    PWCToday Regular stonehenge's Avatar
    Mar 2004
    San Dimas
    Re: '92 750sx
    Engine compartment turned out *****en! Lets get it up to JetTrim for the mats.
    The only problem with socialism is, you eventually run out of other people's money.
