Kawaski SC 750 Conversion Build! - Page 3
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 62
    Re: Kawaski SC 750 Conversion Build!
    With the mods you are planning this should run pretty good, I installed a 750 smallpin in mine with stock exhaust and 38mm carb and really other than pulling through a turn instead of falling on its face in turns there wasn't that much difference in speed, going big pin with an STS exhaust , dual carbs and 180 lbs compression this go around.
    Michigan
    I think the Coffmans pipe, SSXI green head, PJS water box and the Mikuni 44 SBN will make this thing come alive a bit.. The stock pipe and massive water box had to limit that 750 quite a bit. This combination of parts should take advantage of the small pins low end grunt. The Coffmans pipe is massive!
    Yes the STS pipe is basically and OEM coffman, the ebay link shows the back half of one.
    http://www.ebay.com/itm/KAWASAKI-STS...item5d34d12274
    SE MI
    I have one of those said STS 750's and that pipe IS huge.
    Top Dog Goong Gang's Avatar
    Oct 2013
    Brisbane Australia
    I have an 800 Super Chicken!
    I have been through a lot with this Ski. At present it does 41.8. But I hop to get high 40's with a few extra mods.
    Michigan
    Quote Originally Posted by Goong Gang View Post
    Post some pics of your SC on this thread. I Would love to see it!
    PWCToday.com Is My Home Away From Home beerdart's Avatar
    May 2005
    CT
    sent from beerdarts cell device.
    SE MI
    Cylinder bored - check
    Cylinder installed - check
    Head installed -check
    Flywheel lapped - check
    Bending and flywheel installed - check
    Front cover is next along with an ebox checkout then.....
  9. #29
    Oct 2013
    Brisbane Australia
    The 41.8 that I got was with a Skat 9/17 doing 7050rpm.
  10. #30
    Oct 2013
    Brisbane Australia
    Will take some pictures and post them late next week.
