Kawaski SC 750 Conversion Build!
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 62
    Michigan
    One of my good friends has become a vintage ski addict and he prefers unique watercraft. Last fall I helped him put together an X2 with with a few bolt on goodies and he also owns a Sea-Doo HX and two Kawasaki SC's.
    One of his SC's will be the subject for this build thread. Plans are to drop a freshly rebuilt small pin 750 (Built by the capable hands of BLrider) with a 44 Mikuni SBN, Coffmans pipe and possibly a PJS water box. Impeller options are still being considered before a choice is made.
    This should be a fairly simple and fun build with hope to wake this SC up a bit with some much needed horsepower and torque.
    I just need to clear some room in my garage and the patient will soon be under the knife. Pictures will be added soon..
    SE MI
    Re: Kawaski SC 750 Conversion Build!
    This should be a bunch of fun to play on!
    Michigan
    Wait until you see the pictures of this thing! It has a pretty wild Bay Watch theme going on....
    PWCToday.com Is My Home Away From Home beerdart's Avatar
    May 2005
    CT
    I have a same set-up in mine its a blast to ride..
    Michigan
    Quote Originally Posted by beerdart View Post
    What impeller pitch and brand did you go with? Did you use the Coffmans pipe? If so, what water box? Thanks!!
    May 2005
    CT
    Currently it has a stock cut SXR but I need more RPM,s its turning 6200 @ 40MPH. I just dropped in a Skat SX650 prop to see where the RPM,s are. Its a Coffmans pipe and waterbox.
    Pics and info>>> http://www.pwctoday.com/showthread.p...19#post4030119
    Michigan
    Thank you for the input.. I also went through your thread to get as much information as possible. Thanks again!
    Michigan
    Some photos of the SC before the transplant begins!
    Michigan
    SC parts are piling up! Kurt should be done rebuilding the 750 engine soon and I will have pretty much everything ready for the build.. Still up in the air about the water box. We are considering using a PJS box or perhaps a Sea Doo box that I have. Mock up will give us more information as I move forward. I hope to have room in my garage soon so I can pull the 650 engine and pump.
    we are all looking for the hero we need... an 800 SUPER CHICKEN!!!!
    1994 1100 SJ - Dead
    1996 spec hx
