Just bought a Blaster 1 with waveraider 1100 in it..... - Page 3
Page 3 of 68 FirstFirst 123451353 ... LastLast
Results 21 to 30 of 672
    Sep 2008
    City of Blasters
    Re: Just bought a Blaster 1 with waveraider 1100 in it.....
    some info here
    http://www.pwctoday.com/showthread.php?t=357802
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Traci Cottle Photography
    Greg Barnhart Photography
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
    PWCToday.com Is My Home Away From Home tonyvisone's Avatar
    May 2010
    New Hamshire
    nice, and not fiberglass cutting for that? so the diameter is much smaller than the wave venture box....
    any opinions on what my ski has in it now? that watercraft silencer? do i lose power (backpressure) with it? and is the waterbox much quieter?
    also any advice on the prop/cavitation issue? and if a throttle butterfly spring can be removed for easier throttle pull?
    87 JS550- WC reed cyl.. 51 mph
    89 Jet Mate 750
    91 chicken 750 big pin in progress
    93 B1 1100
    93 750sx
    94 750sx
    94 B1 760
    97 Doo GTX bought new
    May 2010
    New Hamshire
    Is this bypass supposed to work as a flush too?? It goes to the pipe
    89 Jet Mate 750
    93 B1 1100
    93 750sx
    94 750sx
    94 B1 760
    Sep 2008
    City of Blasters
    You can remove two springs from the carbs. You can try a 16/21 or 16/23 prop. The silencer doesn't work as well as the water box.
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
    May 2010
    New Hamshire
    silencer doesnt work as well as the waterbox for power, sound, or both?
    89 Jet Mate 750
    93 B1 1100
    93 750sx
    94 750sx
    94 B1 760
    Sep 2008
    City of Blasters
    Sound and power.
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
    I dream skis cstein's Avatar
    Sep 2013
    Long Island, NY
    I have a raider #1 and #2 box if you are interested.. I'm building an 1100 blaster but I have the extreme throttle rear exhaust kit and don't need my raider boxes (or box #1). I picked up a waveraider 1100 last year and have most of the parts left including most of the motor, all electronics, and almost every nut/bolt/cable if you need anything else.
    May 2010
    New Hamshire
    ^PM'ed
    i should keep running BR8HS spark plugs right? thats what was in it and thats what the sticker on the exhaust says
    89 Jet Mate 750
    93 B1 1100
    93 750sx
    94 750sx
    94 B1 760
  9. #29
    Top Dog joesuperjet's Avatar
    Oct 2002
    Blaster-burg
    Keep an eye on those couplers. You might want to slide the engine a few C hairs forward, to get a little gap between the two. The engine vibrates up, down, left,right, forward, and back. Problem is, set up like that - the engine can't really move backwards much. The fingers will start to eat into the face of the other coupler, and you will start to see some metal dusting under the couplers, laying in the hull.
    Team Two Minute Hold
    " GIMMIE 2 "
    www.nynjapwc.com
    Judge Motorsports
    JAM RACING
    ADA Racing
    Quote Originally Posted by momarski View Post
    I want educate not encarcerate
    Quote Originally Posted by tshank123 View Post
    conservative thinking is founded in logic, and progressive thinking is founded in emotion. Although the progressives have the best of intentions, their ideas are completely illogical and flawed. This is backed up with plenty of historical evidence, which they completely disregard.
  10. #30
    May 2010
    New Hamshire
    Finishing up a sled in the next couple nights then digging into the ski more (carbs, water box and a few other small things).
    Looks like ill need to cut about this much off te coupler cover. Seem normal?
    89 Jet Mate 750
    93 B1 1100
    93 750sx
    94 750sx
    94 B1 760
