If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
swapped the ECM, it must be bad. The other one went dead with the same symptoms. The one with the issues fired right up. I imagine there is no repair and it must be replaced and key reprogrammed?
non supercharged 08 wake 155. really sucks, the machine is otherwise in mint shape, I have like 80 hrs on it total, too bad I owned it so long and it is out of warranty
Shouldn't be but a half hour of labor charge. Don't let them pull your pants down and give it to you hard. Maybe call them and ask for service and explain quickly and clearly what issue is. I'm no expert but try to help
I appreciate the help. I'll start looking for a replacement and call the shop for a test as you suggested. Also gonna really inspect the thing and make sure I have good contact from all the pins etc....
Comment
