Page 76 of 81 FirstFirst ... 26667475767778 ... LastLast
Results 751 to 760 of 802
  1. #751
    Re: The 650sx Brotherhood
    its hopefully finished,
    or at least mechanically. I hope so. going to try to test it tomorrow
    4 years between start and finish
  2. #752
    Dec 2014
    SRQ FL
    Maiden voyage for the 750sp swapped 650sx, running a mariner 3 piece large chamber and dual 40's. Ripped crazy good til I found a small exhaust leak in the headpipe. Getting it all fixed up and gonna try again next week!
    1992 Kawasaki SP 750sx - Big pin cyl, 1 mil overbore, Triton Engineering head, V-Force Carbon v3 reeds, Coffman Signature series pipe and silencer / WB bypass, dual SBN44 on R&D dual singles, Blowsion F/A, AC Racing -2 alum pole, Jetworks bars, full Jettrim, OP rideplate, Westcoast scoop grate, OP steer nozzle, blueprinted aluminum pump nozzle
  3. #753
    Oct 2017
    New 650 brother here. Been riding my ski for the last three seasons and love it. Please check out my post in the newbie section. A little tedious but I can post pictures of my motor work in a week or so when I tear it down to put in a new crank if anyone in interested.
    I would really like to get some information concerning boring the pump housing to 144 mms. Where would be the best place to post a question on boring the housing.
  4. #754
    Oct 2017
    post_image4(1).jpgpost_image2(1).jpg My 87 650sx . Bought it new at the dealer . went to work on it got lot of goodies .west coast pipe intake . ocean pro head reeds and lot more. I have 8 skis . But she's my baby cause she was my 1st.
  5. #755
    So i have an issue thats got me stumped.
    Been testing my 650 after the build. Very stable and happy with the hulls performance.
    However can't get the motor to rev out.
    Carb has been swapped for a sbn44
    Jetting is 110 and 140. Bogs down. Then comes good at about 1/4 throttle. Just sits there and wont rev higher. Tried adjusting the low speed from 1/2 turn to 2 turns in range. Seems to be best at 1 turn. But thats where it was when i started.
    The high speeds been between 1/2 and one turn. No noticeable difference so assume its not getting anywhere near it kicking in.
    Just can't get it to make any improvements. Any chance its an airleak in the crankcase? Had an issue with the thread on one of the crankcase drain block-off plate bolts.
    Otherwise its 2 weeks before a ski mechanic can tune it for me
  6. #756
    Dec 2009
    What's your pop off?
  7. #757
    Aug 2010
    what he said ? wheres it at ^^^^^. where's your timing at IE: when you put the stator plate on the motor, ???? do you have a nice blue spark,,?? are the plugs new , even so, stick some old used ones in, you could have only 1 cylinder firing ,chop the plug leads back a little till you get clean wire >post compression test #s .
    modded X2 650
    Originally Posted by hyosung
  8. #758
    I dream skis sportsfreak29's Avatar
    Oct 2011
    Midland, Tx.
    I run a 115 low, 145 high, 2.3 needle and seat with 21 psi pop off. See ski specs in my signature.
    Like it was mentioned above, check the pop off. If it's too low, it will be rich on the bottom and bog, and the fouled plugs will kill the top.
    Too much water in the exhaust can also cause your problem.
    '84 js550/650 Hull, Tubbies, Footholds, 650sx Motor & Pump, 1.75 over 663cc's, OP Comp Head 190psi, 44SBN, Vortex FA, WC Intake, Boyesen Reeds w/ Stuffers, Factory B Pipe, Factory Waterbox, 650 Side Exhaust, Dual Cooling, Billet Couplers, Jet Works FCV, OP 650sx Ride Plate, PJS Top Loader, Skat 9-17, -2" AM Pole, MSD total loss. 54mph.
    Special thanks to Chris Newmiller, and Mitchell at M&M Marine!
  9. #759
    Frequent Poster 92Kawasaki750SS's Avatar
    Jul 2015
    United States
    Is anyone running the Pro watercraft Racing mid or rear sponsons on there 650sx? Any photos? And if so, how do you like them?
  10. #760
    I thought there was too many variables. I'm happy and satisfied with taking this neglected and seized example, turning it into a running ski.
    I'll let someone more experienced do the black magic of tuning.
    (Oh and the chin pad is off getting done by a professional. Strugled enough with the hydroturf. And this will need the foam rebuilt. Paint will be done... eventually)
