Rough sun baked rub rails
Results 1 to 10 of 11
    Jun 2009
    Texas
    Whats the best thing to do to rough sun baked rub rails, they're black ones. I tried a heat gun, but didn't really see much change.
    Sep 2007
    Utah
    Re: Rough sun baked rub rails
    Quote Originally Posted by Green95LX View Post
    buff the peach fuzz off of them with a 3M pad then hit them with wipe-new.
    Top Dog hooka-2's Avatar
    Nov 2005
    sebring florida
    scrape them with a razor blade at a 90 degree angle. It will peel off the fuzzy oxidized layer and then use a heat gun it necessary to gloss it up
    90 X2 (750), 92 X2 (750), 93 X2 (750),93 X2 (750), 99 Ultra 150(sold) 1995 Waveblaster 1
    Mar 2005
    Michigan
    I use turtle wax trim restore on my 96xp rails and it works pretty good.
    Jun 2009
    Texas
    Quote Originally Posted by fastgas View Post
    3m wool pad?
    Sep 2007
    Utah
    3m wool pad?
    one of those green or blue scrubber pads.
    Aug 2009
    MA
    I used softscrub and a fine scotchbrite pad. Then shined up looking near new with that turtlewax trim restorer...good stuff but it leaks all over and is very oily.
    Jul 2010
    Feton MI
    I use sos pads on those and any of the faded plastic.
    Here's a vid I made of the way I do it. http://www.youtube.com/watch?v=-DKqQIptL3c
    Sep 2007
    Utah
    I've been working on the wife's 97 XP. I scrubbed the rear and part of the starboard rails with a 3M scrubber then hit them with wipe new:
    You can see both the untreated rail and unbuffed/polished gelcoat (i've got a long way to go, under the water line as well!)
