Page 3 of 14 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 140
    PWCToday Guru Jamesbechina's Avatar
    Apr 2012
    United States
    Re: Kawasaki x2 Flatdeck Build.
    Quote Originally Posted by Matt742 View Post
    What are you doing for air for the motor?
    I'm going to run 4 1" PVC pipes from under the cowl and them extend them down In front of my motor.
    Kawasaki X2 - 750sp, Factory pipe with 650 chamber, GRS 46mm Carb, Westcoast manifold, Stock milled Head, Cart Tank, UMI, Rear exhaust, Versiplug, Skat 10/18 with R&D afterburner pump stuffer, Rad Dudes Surf brace, 94' Graphics, Rear exhaust.
    Apr 2012
    United States
    I hope none of you have to replace your steering and trim tubes. What a pain in the butt to get all of that kawasaki green epoxy off and get the fittings out.
    Looks like temps are going to be nearing 40 by the end of the week hopefully I'll get my exhaust put in and foam poured soon.
    Frequent Poster Matt742's Avatar
    Sep 2013
    Goodyear az
    oh yeah i like that idea. did you cut all the ducts out of your hood as well?
    ill have to post some pics when i do mine i have a bit of a different idea
    Oct 2012
    Belgium
    extra air ducks ( air vents ) by the steering ( works great on my other builds )
    http://www.pwctoday.com/showthread.p...56#post4009656
    Apr 2012
    United States
    Im not going to go as extreme as you jack but I am going to try to do all the venting through the hood. Very cool though jack!
    Also just added a factory pipe instead of my coffmans pipe.
    PWCToday Guru howie_hoe's Avatar
    Jul 2012
    Peotone illinois
    Looks good. Making any progress?
    Apr 2012
    United States
    Waiting on my stainless exhaust tube to get in. Hopefully monday then I can install that and foam the ski. Then I can lay some glass and prep for paint. Im so close but so far away at the same time!
    Apr 2012
    United States
    Traded my coffmans exhaust mani to blasterdude for a westcoast mani and surf brace! Thanks again
    I also scored a sweet set of 94' graphics for the ski once its all done!
    I am stoked I have almost all the parts I need to finish this build!
  9. #29
    Jul 2012
    Peotone illinois
    Where did you get the graphics? I need some for my build
  10. #30
    Apr 2012
    United States
    I got them from a guy on here in the classified section.
