Page 2 of 14 FirstFirst 123412 ... LastLast
Results 11 to 20 of 140
    PWCToday Guru Jamesbechina's Avatar
    Apr 2012
    United States
    Re: Kawasaki x2 Flatdeck Build.
    Update coming next week. Temps getting above freezing! Wahooo!
    Kawasaki X2 - 750sp, Factory pipe with 650 chamber, GRS 46mm Carb, Westcoast manifold, Stock milled Head, Cart Tank, UMI, Rear exhaust, Versiplug, Skat 10/18 with R&D afterburner pump stuffer, Rad Dudes Surf brace, 94' Graphics, Rear exhaust.
    Apr 2012
    United States
    Small update. Routing the scupper. Can't decide if I want a versi plug or to use my epic scupper.
    Found out that my through hull bearing is toast. Power washing the rest of the foam out tomorrow.
    Apr 2012
    United States
    Anyone have suggestions on how to get the green kawi goop off the hull? I feel like I am dealing with some Nasa technology. My trim line was toast so I cut them and got the pump fittings out but I cant seen to get the engine compartment ones out.
    Oct 2012
    Belgium
    Quote Originally Posted by Jamesbechina View Post
    are you using PVC as exhaust tube ? or just bildge
    Apr 2012
    United States
    For the versi plug. I will have stainless steel exhaust.
    Apr 2012
    United States
    I am waiting on some warmer temps. I am ready to pour some foam but I need to get my garage up to 70 degrees. Gotta love South Dakota winters.
    Apr 2012
    United States
    Got the good all glassed up tonight
    Frequent Poster Matt742's Avatar
    Sep 2013
    Goodyear az
    Red cups would be a much cheaper way to mix my resin! Man I've been spending a fortune on buckets from Home Depot!
    Sep 2013
    Goodyear az
    What are you doing for air for the motor?
    Oct 2012
    Belgium
    Quote Originally Posted by Matt742 View Post
    http://www.pwctoday.com/showthread.php?t=414540&page=4 #75
