XiR 1100 conversion
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
    PWCToday.com Is My Home Away From Home ko2's Avatar
    Ski Whoareville, NY.
    XiR 1100 conversion
    The plan initially was to simply resurrect a very limited production classic piece of jet ski history. But we ended up buying more Kawi 1100 donor skis than we had planned this past fall .. so with an abundance of parts, we figure what the hell. Although we have three other conversions going on, the XiR needs a triple. Especially after speaking with Scottie Mac today, who got us all excited about that hull, it's handling characteristics & general overall performance with an 1100 under it's skirt.
    So here is what we have done thus far ;
    Figured out that a stock ZXI drive shaft will work - but needs to be shortened 33mm's & re-threaded.
    1100 bed plate - rear mounting holes line right up to stock XiR motor mounts. In order to utilize the front XiR motor mounts we had to drill two holes in the 1100 bed plate. Unfortunately the stringers don't extend much further forward than the front motor mount positions, so we are going to glass in threaded inserts so that we may run two additional motor mounts - equaling six mounts in total.
    Expansion chamber has been cut - we are avoiding cutting the hull & of foot tray area .. but we are going to need to remove some of the rear bulkhead in the back of the engine compartment.
    Will continue to post pics as we get deeper into this .. man, this shat is a blast !
    LIVE Jet Ski RADIO - every Wednesday at 7:00pm eastern standard time.
    Link: www.mixlr.com/watercraft-network
    Resident Guru jdakrt's Avatar
    Mar 2006
    Chesterfield VA
    Re: XiR 1100 conversion
    Another one! Awesome!
    "PITD" proud member of
    Team TFP
    There can't be many others out there ? .. Yours, Robinson's & one other out west that I know of.
    Mar 2006
    Chesterfield VA
    Correct. Not too many, which makes another one in the fleet exciting! Wish someone would buy mine and get it on the water....
    Team TFP
    jd - did yo u have cut into the rear bulkhead in order for the exhaust to clear ?
    Mar 2006
    Chesterfield VA
    No, the team boats really didnt have a bulkhead per say, just a pump tunnel cover...
    Team TFP
    Jul 2012
    Hyde Park, NY
    cant you try a sxr bed plate ? thats works for all the stand up skis. this way your still on the stringer
    Mar 2006
    Chesterfield VA
    There is no room aft of the coupler. I.e the xirs motor is setback so far the driveshaft coupler is basically 1/2" off the bulkhead. You cannot "split the difference" of the extra cyl like on the sxr.
    Team TFP
    Oct 2009
    Jersey Shore
    And to think, I was going to part out my red runabout! Add one more to Open R/A Spec class!
    Sep 2008
    City of Blasters
    There's 2 out west now and a 3rd is knocking on the door.
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Traci Cottle Photography
    Greg Barnhart Photography
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
