550 reed half pipe
Results 1 to 10 of 12
    PWCToday Regular Roofingseth's Avatar
    Oklahoma
    550 reed half pipe
    How do you know the difference between the reed exhaust and the piston port half i have both of these pipe
    Sent from my iPhone using Tapatalk - now Free
    Mar 2007
    Is Everything!
    Re: 550 reed half pipe
    The first pipe is the one manufactured for reed motors.
    Oklahoma
    Ok thank you
    Mar 2007
    Is Everything!
    Make sure you use the correct gaskets
    http://www.pwctoday.com/showthread.p...731&highlight=
    Oklahoma
    So what is the difference in the two as far as performance
    Oklahoma
    I ordered some from factory performance
    Top Dog Rompn's Avatar
    Aug 2004
    La Crescenta, CA
    Yes the top photo is a reed specific half pipe. It has the lord mount, is slightly fatter at the bend and I believe 1" shorter/longer. Can never remember which. The piston port specific pipe is more fluent in the bend area and no lord mount. Either pipe will work on either engine however as they will bolt right up. There's just a slight difference in performance using the correct pipe. As stated, use the correct gaskets and if installing the reed pipe on the reed engine, it is stated in the directions from Factory to change all three gaskets as they are a different thickness as the OEM ones and need to be equal throughout the exhaust.
    Patrick Goldsworthy
    Region 1 / Vintage Ski / #28
    Chris "Fish" Fischetti & Victor "The Slasher" Sheldon
    Oklahoma
    I got the right gaskets. I ordered all three from the factory performance company there cheaper from the link above but I like having the right stuff.
    Mar 2020
    Sandy or
    Do you want to sell the half pipe!
    Mar 2007
    Is Everything!
    He may be tired of them both after 7 years...
