750 sxi weak spark - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 38
  1. #21
    ann arbor mi
    Re: 750 sxi weak spark
    well when i tested before i bought it i used his battery and it ran. put in my 2 year old battery and it cranked it fine at the lake but now its shot and wont take a full charge. so your saying it could have cranked over good but not supply enough volts to the coil itself. i wonder if that is it i hope. could that also be why its intermittent as well.
  2. #22
    PWCToday Guru youcantkeepup's Avatar
    Jun 2011
    Rochester, NY
    yes.. thats exactaly what was happning to us... we were beating out heads against the wall
  3. #23
    PWCToday.com Is My Home Away From Home seadoobutch787's Avatar
    Send your coil to JSS and put some br8eix plugs in there, it will run a lot better.
  4. #24
    Sin City USA
    Quote Originally Posted by lawnkid14 View Post
    I got an owners Manuel but not a service Manuel. For the test I even took the boots off and did wire to wire
    Shoot me an email address and I will get you a service manual.
  5. #25
    ann arbor mi
    thoes are what is in there right now. also will pre mix seem clear if i have a clear primer line. or should it still have a tint to it
  6. #26
    Jun 2011
    Rochester, NY
    depends on the color of the oil.. please try the battery.. even if you steal it from your lawn mower just to test
  7. #27
    ann arbor mi
    So with a jump it started does that mean its just the battery
  8. #28
    Jun 2011
    Rochester, NY
    yes very likely.. just go grab a new battery, if you have a volt meter just see how low the battery drops while cranking with the spark plugs in
  9. #29
    ann arbor mi
    if i buy a battery now wont i loose a season out of it because i will use it a few more times and then it will sit, i was looking at batteries plus agm battery for it. how good are those batteries?
  10. #30
    ann arbor mi
    also i think if its just the battery then over the winter i will still send out my coil to jss.
