Results 1 to 9 of 9
Thread: Honda f15x eBay
    PWCToday Regular TimL's Avatar
    Southern Indiana
    Honda f15x eBay
    2008 f15x on eBay for a very good price!! Wish I had the money I would gladly pay the buy it now price of 7k😪
    resident guru CelticCrew's Avatar
    Jul 2009
    Frederick, MD
    Re: Honda f15x eBay
    It does look nice.
    The List
    2005 Aquatrax F-12X (Macsboost Module, Torxracing IC, Custom Air Intake)
    2002 Aquatrax F-12X (Macsboost Module, Torxracing IC, 17/29 Solas, Plenum spacer, Custom Air Intake, Velocity Stack Insert)
    Jun 2013
    Richmond, Virginia
    Re: Honda f15x eBay
    I asked for detailed pics - would not reply directly. The old saying... if it's too good to be true, it usually is.
    2017 Yamaha GP 1800 (Riva stage one re-flash and intake, Candoo Pro GPS)
    2007 Honda F-12X GPScape w/ MACSBoost Plug-in Module and Intercooler
    2013 Cobalt 232 w/ 350 Mag and Bravo 3
    Top Dog spatera's Avatar
    Jul 2006
    South Ga
    Re: Honda f15x eBay
    03 Honda F12X (my favorite) Red of course
    Used to have:
    98 GP760, 97 GTX Sea Doo, 97 GP1200, 02 Honda F12X, 2-03 Honda F12X, 05 SeaDoo GTX Supercharged
    Need to have:
    F15X
    Southern Indiana
    Re: Honda f15x eBay
    looks like the resale on these 15's is coming down a bit, I might acually be able to afford one soon
    Southern Indiana
    Re: Honda f15x eBay
    spatera, did you ever post a review on the alpha boost kit? I've been thinking of trying one.
    Jul 2006
    South Ga
    Re: Honda f15x eBay
    No, there were so many when I installed mine. It's very easy to install and I like it cause the pull is linear from idle to wide open. There is no second hit from the turbo spooling up. Now if your looking for an easier set up, although more money look at the MacBoost. It's a nice product and does work. My friend has one on his ski and they are pretty much identical in speed. We both turn about 6450 rpm, same grate and impeller. I don't know what the true speed is but we're real close. I tell him mine's faster cause the red ones are.
    Used to have:
    Need to have:
    F15X
    Southern Indiana
    Re: Honda f15x eBay
    My F12-X tops out at 6000 rpm(never a blip more) and the speedo indicates 61-62mph, does it ever trigger a code?
    Jul 2006
    South Ga
    Re: Honda f15x eBay
    Add some boost and you'll see your rpm go up. To me there's not a huge increase in top end but getting there is a whole lot more fun. I don't know what the speed would be on a stock impeller and I don't trust the dream-O-meter. Both the regulators and the macboost trick the ecm so it doesn't know your boosted and therefore no alarms. I only run about 17 psi cause I'm afraid there's not enough fuel delivery with the increase in boost. If you want to try the regs, Jim can supply all the stuff you need in one kit. Either way you go, you'll like the difference.
    Used to have:
    Need to have:
    F15X
