Results 11 to 20 of 34
    PWCToday Newbie MadsMax's Avatar
    Aug 2013
    Oslo, Norway
    Re: Replace Starter - Yamaha WaveRunner VX 110 sport
    The starter is fixed, gave it a huge cleanover and installed it back in the VX, that job sucked
    Thank you Frenchie!
    Die or live hard
    Prowd owner of;
    2x Yamaha WaveRunner VX 110 Sport (2005)
    1x Double custom made trailer - road legal.
    Dec 2007
    st pete beach florida
    Sorry for the late answer, yes you can save and fix the starter if the rust is not too much, like i told you the brushes were stuck in their support.
    Good job saving it and if you put plenty of grease on the nose over the oring it will go back in easy .
    When i do this job i also clean and repaint the carcass and reinstall the 2 large orings with gasket sealant.
    Apr 2014
    jacksonville
    I have to replace my starter I can harder get my hands under there.
    Dec 2007
    lean over the engine , your wrench will fit underneath the exhaust manifold, 12mm socket with extension and ratchet will do it
    Jul 2014
    Orlando, Fl
    Nice write up thanks. I wish more people would do this. The pic's are worth a thousand words.
    PWCToday Regular RickM46's Avatar
    Sep 2014
    Indiana
    MadsMax,
    I am kind of curious:
    Were you the original owner; why would one boat have this problem and not the other; for the starter to be that corroded, was the boat flipped; is there water in the hull; water in the oil; corrosion elsewhere??
    Anyway, great thread; congrats on the fix,
    RickM46
    Apr 2015
    Puerto Rico
    Hi, how did you manage to get your hands under the exhaust. It's almost impossible to reach the 2 screws.
    Dec 2007
    easy to reach if you lean over the engine from the left side, 2 12 mm bolts on the rear and 1 10mm nut for the wire, pray the starter out of the block and if frozen bang it out from front to back with a long socket extension between block and exhaust manifold, you will feel it.
    Apr 2015
    Puerto Rico
    Quote Originally Posted by cyrillefrenchy View Post
    After almost two hours, I finally was able to get it out. Thanks for the tip.
    May 2016
    Orlando FL
    i was able to get it out, but could not get the new starter in... eventually i took to a friends mechanic shop and his guys did it for me.
