Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 47
Thread: mid shaft leak
  1. #31
    PWCToday Regular GStrans's Avatar
    Apr 2013
    Hobe Sound Florida
    Re: mid shaft leak
    Does not have to be running.
  2. #32
    Apr 2006
    Southern British Columbia
    Re: mid shaft leak
    ok, thanks!
    Please excuse some of my replies, my English is not very good so I may misunderstand your question or my reply to your question may not make sense.
  3. #33
    May 2008
    Crestwood, Ky
    Re: mid shaft leak
    What is the secret to getting the drive shaft out? Mine doesn't want to budge!!
  4. #34
    May 2008
    Crestwood, Ky
    Re: mid shaft leak
    I have tried hitting the coupler with a dead blow hammer and still no movement. I don't what to break the coupler pounding on it. Any ideas?
  5. #35
    Dec 2007
    st pete beach florida
    Re: mid shaft leak
    is the cap with the 4 bolts holding driveshaft bearing out? if yes then the shaft is frozen into the prop. using the hammer is right, if it does not come out then cut the shaft with grinding wheel thru tunnel with intake grate off to separate .
    The Jetski Repair Shop
    South Pasadena Florida
  6. #36
    May 2008
    Crestwood, Ky
    Re: mid shaft leak
    Yes the cap is off, had to cut 3 of the 4 bolts to get it off.
    Ok, just keep at it with hammer till breaks loose or damage the coupler, then cut!
  7. #37
    May 2008
    Crestwood, Ky
    Re: mid shaft leak
    If I do end up cutting, does the shaft usually stay corroded to impeller, requiring a new imp, or is there a way to separate?
    Also is the coupler usually stuck as well?
  8. #38
    May 2008
    Crestwood, Ky
    Re: mid shaft leak
    Well it doesn't matter now because the coupler is in 3 pieces! Gonna get cutting the shaft.
  9. #39
    Dec 2007
    Re: mid shaft leak
    yes cut the shaft to separate, then make 2 flat spots with grinding wheel on remaining piece of shaft to be able to put a pipe wrench and unbolt prop from jet pump (reverse thread) then when the prop is out , the center of the prop is hollow and will punch out or press out remaining piece of the shaft from inside of the thread out. not easy sometimes but the best way i found so far.
  10. #40
    Re: mid shaft leak
    So much fun in this thread.
    Not difficult but can be a PITA. I am numb to doing these...great job Yamaha.
    Use a heat gun on the remaining glue & it will come right off.
