    NC
    Questions - Replacing Throttle Cable
    I'm getting ready to replace the throttle cable in my 1999 Seadoo XP Limited. It looks like I'm going to have to remove the muffler assembly to reach the carb assembly. If that's the case will I need new gaskets when I reinstall the muffler assembly? Also is there an easy way to keep the cables on my watercraft lubricated? I keep this watercraft (and a 2004 Seadoo RXP) on lifts parked over brackish water. Thanks in advance.
    PWCToday.com Is My Home Away From Home Tom V's Avatar
    TarponSprings FL
    Re: Questions - Replacing Throttle Cable
    Don't re use any gaskets, replace what ever is removed, unfortunately there is no good way to keep the cables lubed.
    www.shopsbt.com
    The Worlds Largest PWC Engine Remanufacturer
    94 sl 750 (sold)
    99 slh 700 (sold)
    2000 pro 1200 (sold) old race ski
    2001 genesis
    96 superjet 701(sold)
    97 Hurricane
    97 sl 700 to 1200 conversion
    03 octane (sold)
    97 sltx 1050
    96 Hx limited class
    07 GTI se 155
    05 150 sportster 215
    98 PRO 785
    We can't solve problems by using the same kind of
    thinking we used when we created them.
    --Albert Einstein
    Top Dog wire4money's Avatar
    Aug 2008
    Central Oregon
    You can remove the carbs without disturbing the pipe. If the pipe doesn't leak, I wouldn't touch it. It is a common leak point on 951s. Remove the airbox assembly, move the oil reservior, remove the 4 Allen bolts holding the carbs on with a ball end wrench, and pull the carbs out through where the oil tank was. You could probably replace th cable without removing the carbs, though
