Is a 650 REALLY that much better than a minor-ly modded 550js?
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
    PWCToday Regular konakev's Avatar
    May 2013
    SOCAL
    I have a js550 that has coffman half pipe, 40mm carb, milled head, ported exhaust ports, mariner intake, racing intake grate, skat trak impeller. maybe forgetting some? its pretty quick and all, but im looking for a little more speed and power (not funded enough for a newer 701 quite yet) but still...i havent ridden a good-running 650sx yet and I was wondering... Is it REALLY worth making a switch to sell my 550, and go for a 650? or will i be dissapointed with power and top speed? Everyones opinions greatly appreciated!
    I dream skis lomofo's Avatar
    Mar 2013
    O-Town Cali
    Re: Is a 650 REALLY that much better than a minor-ly modded 550js?
    You will be dis-appointed with the ride quality, if you are happy with the 550 hull.
    I would bet you'll have to put some work into the 650 to beat your set-up on power as well (easily doable, and in-expensive to bump initially).
    Paople do conversions, with the 650 into the 550 hull; do a search and read some happy campers...
    T
    lomofo go bye-bye; We'll be steppin' up the tech game a rung or two...
    Frequent Poster surf shreder's Avatar
    Oct 2006
    pensacola FL
    Been there done that trust me do the conversion to 650.
    PWCToday Newbie Lkeredy550's Avatar
    Jan 2013
    flagstaff
    I would research the conversion option.
    I dream skis waterhappy's Avatar
    Jul 2009
    LHC AZ
    Try a 650 first, I love mine but mine has a lot of money dropped on it. Remember when looking for a ski that most of them probably won't be as well maintained as your 550.
    Frequent Poster jetfreak's Avatar
    Netherlands
    go for the conversion, then you have the best off both! Switching from a modded 550 to a stock 650 is a disappointment!
    1100SXR
    750/800 conversion
    550JS
    550SX
    550/650 conversion
    650 X2
    Laserjet F14
    Resident Guru Durhamgoat's Avatar
    Jun 2008
    Jasper IN
    If you like the 550 hull then the 650 will feel like a boat. Put a 750 in your 550 and you will never have to look back...
    440 JS Stock
    440 PJS ski with ported cylinders, shaved head, pjs exhaust, pjs pump and exit nozzle, etc.
    550-750 Build...http://www.pwctoday.com/showthread.php?t=397055
    SE MI
    The SX's are fun but feel heavy and your ski is probably more powerful (power to weight ratio). As stated, if you like the ride of the 550 the 650 will feel like a freighter. Doing a conversion (650/750 engine in your 550 hull) will change the ride a little too but not in a negative way and the added power makes the 550 hull a blast.
    PWCToday Guru TLR67's Avatar
    Jan 2013
    North GA
    650's are big... But so I am I at 6'2 255... The fit is perfect....
    Jun 2008
    Bay City, Michigan
    550 is much lighter and nimble. the 650 is a turd-ski. poor handling... sell that engine and all the parts and buy a doner boner 750 ski for engine and drop kick the hull
