Jetting Guru's! Dual 3 jet Keihin CDK2 40's help! - Page 16
Page 16 of 19 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 187
  1. #151
    Chicago / Portage, MI
    Mucho Garcias bandit. Main jets: https://www.jetsrus.com/a_jets_by_ca...4-36_main.html
    Pilot jets: https://www.jetsrus.com/a_jets_by_ca...4-35_slow.html
    I only see two different weight pop off springs, is that all there is or do you have a source for pop off springs? How about jet blocks??
    Chris I get my Keihin jets from Atlantic Jet Sports. But yea a few places have them. The actual Keihin rebuild kits come with springs. Beyond that, I have never had to change a needle and seat yet.
    Also to be clear, the good carbs were on 94 and 95 small pin ss xis and xirs. The rest of the dual 750 Keihins are not all good, the later (38mm?) ones off the big pin were smaller and I would dump in the trash. I did a quick check and it looks like the 96 ss xi switched to big pin / 12 bolt intake / smaller 2 jet Keihins.
    So for those of you out there who are interested in Keihins, be careful which ones you get. You want the dual 40mm Keihin CDK2s off the original dual carb small pins for sit downs. They came on the lime green head engines, but may not be exclusive to those engines. Also of note the 95 sxi came with different, 2 jet versions of the original good 40mm Keihin CDK2s. That is a different topic entirely.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1995 SJ MINT:
    [TBD]
  2. #152
    Quote Originally Posted by Jdbarnes89 View Post
    Well can't say for sure until i water test..... But i think i figured out the issue..... I almost don't want to admit my mistake lol, but i got to looking at a diagram of these cdk2 and realized i had put the gasket on the invites side of the diaphragm...... �� Needless to say it runs a bit better on a hose at 1 turn out each but we shall see what happens with a load on it I'll report back but thank you all for the info!!!! Even if i made a dummy move assembling them lol I'll see what happens with the 135, 55, 78 jetting and go from there!!!
    Lol nice! It's all about figuring it out the issue, and you've made good progress.
    Like I said, I would expect you to be rich now. See how it goes, ideally get a tach or gps and see where you're at.
    2009 1100 SJ:
    2009 SJ MINT:
    1987 WJ650:
    1995 SJ MINT:
    [TBD]
  3. #153
    Jun 2018
    MN
    Well I'm not sure what year mine came from, but they came with a small pin manifold so I'm guessing they are the"good" years you are talking about, now i just need the weather to cooperate so i can retest the ski!
  4. #154
    Jun 2018
    MN
    Yeah it might be a tad rich, i guess we shall see, but it fired up great cold with a couple primer pumps then without the primer after it's warm it fires up easily so i must be close on the low side, I'll have to do some plug chops to get it close, it like you said get a tach
  5. #155
    Riverside, CA
    6
    There was another person that required a richer jetting, he was from
    Spain, and I need to find his posts.
    http://www.pwctoday.com/showthread.php?t=464495
  6. #156
    Jun 2018
    MN
    So i ended up with 5/8 turn out on the high screws and 1 5/8 on bottoms, it seems a bit rich... But when i go to give it throttle there is a bog i tried leaning the low end and it got worse, it wasn't a hesitation but a bog my pop off is about 25psi I'm thinking i need to maybe go back to a 72 low Jet? Think i should go back down to a 50 mid? The bog is right as i throttle to get out of the water, but after the engine gets ran a bit the bog goes away, these carbs are really starting to get frustrating lol I'm really close to going back to the oem 38mm that is like brand new that i have on the shelf.......
  7. #157
    Resident Guru RenoJetTech's Avatar
    Apr 2009
    Reno,Nv.
    Yeah a hesitation would be like you're getting close to proper. Straight out bog is getting away from proper.
    Both screws affect fuel delivery down throat. So , but you may still re-jet later, can you try 1-1/4 high and 1-1/4 low turns out.
    Don't touch the high during next lake test at first, just do your increments on low screws.
    Just responding to above scenario..
    '88 550-ride plate,intake grate,intake manfold,carb
    '96 GTX-1mm overbore,F/a's,intake grate,port timed for mid and top end
    '95 FX 1- usually take this motor to 753cc with exhaust porting and reeds
  8. #158
    Jun 2018
    MN
    All right I will probably get it back on the water tomorrow so I will report back then
  9. #159
    Jun 2018
    MN
    Apparently the pop off have i used is 5psi off so i was running like 18 psi so now i have corrected that, i will see what happens tomorrow after work
  10. #160
    Apr 2009
    Reno,Nv.
    So within a pound of each other and beginning to pop at 24ish ?
