Jetting Guru's! Dual 3 jet Keihin CDK2 40's help! - Page 11
Page 11 of 19 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 187
  1. #101
    Jun 2018
    MN
    Well currently I'm doing a rebuild due to the sleeve cracking on port Bridges, then somehow loosening up in the jug and then dropping down, waiting on a new cylinder to arrive then get bored and matched to my Pistons, i have a weird issue on it though, when i shut the engine down it wants to keep chugging along with these dual carbs, if i put my single 38 keihin on, everything works just fine, but it just doesn't seem nearly as responsive with that carb...
    Almost thinking about setting the dual 40s aside.......
  2. #102
    Chicago / Portage, MI
    Duals are great if you want fuel economy or don't like copying one carb setting to another.
    Meant singles here.. obviously. Lol.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1995 SJ MINT:
    [TBD]
  3. #103
    Quote Originally Posted by Jdbarnes89 View Post
    Wow crazy. That sounds like an air leak. Any time an engine is doing something you didn't pull the throttle for, suspect an air leak. I had a 750 that was vaguely similar and it had a massive crack in the intake manifold and could not hold air at all. If you haven't done it, i would do a leakdown test thru the bottom end right up to the carb base. Make a thick rubber gasket that you can clamp between the manifold and carbs. It should be air tight to 8-10 psi for at least 10 min no drop in pressure. On some of my engines I leave them for an hour just to see. There are threads on here with how to do leakdown tests if you havent done it before. I do it on all my new built engines. Use Threebond 1211 on all surfaces as you build the engine and report back.
    2009 1100 SJ:
    2009 SJ MINT:
    1987 WJ650:
    1995 SJ MINT:
    [TBD]
  4. #104
    Top Dog Benflynn's Avatar
    Aug 2015
    Birmingham
    Just a reminder, all the 3 jet carbs sent the same, they have diff locations of the 3rd jet, and have diff transfer homes at the base, so for Juliette g recommendations you have to be sure all is the same
  5. #105
    Jun 2018
    MN
    I think what i might be experiencing is pre ignition I've been using 91 octane non oxy fuel.... I put things together just to test compression and it was at 185psi and just like diesel fuel, gas will ignite if it's compressed enough, but I'll check into the leak down stuff also
  6. #106
    This is a good point. If I didn't mention it, I should have. My settings apply only to the 3 jet 40mm Keihin CDK2s which came on the 94 ss xi and xir small pin dual carb 750. Maybe some 95 ss xi skis as well, not sure. They came on all lime green head engines but I am not sure if they were exclusive to those. All three jets should be on the same side. This isn't an issue because these are very plentiful.
    Regarding other small pin 40mm options I believe there is at least one, with one jet on the back of the plate the jets thread into. I can't speak to those but i believe they should function the same jetting wise. If you have the smaller 38mm big pin ones, which if I recall correctly also had the jets on different sides, throw them in the trash and get mikunis and manifold off the later big pins 750 pro and sxr.
    2009 1100 SJ:
    2009 SJ MINT:
    1987 WJ650:
    1995 SJ MINT:
    [TBD]
  7. #107
    Jun 2018
    MN
    So are there issues with air leaks at the throttle plates? On these 40s? I'm not sure what to call it, but rod that goes side to side that holds them? Do they get worn out?
  8. #108
    Riverside, CA
    6
    Not really, although all carbs are capable of leaking there.
    The worst carbs for leaking throttle shafts were early snowmobile
    and watercraft cabs like Walbro, Mikuni, Keihin, Tillitson round
    body carbs. The early Mikuni Super BN's were also a problem.
    On all of these carbs, worn out throttle butterflys at each side
    of the throttle shaft, and side to side slop on the throttle shaft
    were a signs of a problem.
    Another source for vacuum leaks occur after you disassemble the
    carb rack. If the carb rack is reassembled without using the intake
    manifold as a jig. It is very likely that a new leak at the carb base
    gaskets will occur.
    I would recommend drilling the 2 bottom low speed bypass holes
    to .024" before installing a #78 or #80 low jet. I believe Kawasaki
    was more concerned with Hours/Gallons and exhaust emission testing
    than other manufactures. I think this is why their Keihin low speed
    bypass holes are so small.
    In 1994, the 900zxi had a low end bog that was solved by drilling
    the lower 2 bypass holes to .024" I tried jetting it richer on the low
    jets and increasing the pilot screws, but modifying the low speed
    bypass holes worked the best.
    DANGER: Only drill the bottom 2 bypass holes!
    Sleeves dropping on small pin cylinders used to be a common
    cause for engine failures
    How do you know it has 185psi? Most compression gauges read low.
    Bill M.
    Any pictures of your old pistons?
  9. #109
    Oct 2012
    Belgium
    following .
  10. #110
    Jun 2018
    MN
    Well i tested compression with 3 testers mine is 30psi low but the other two were the same, the engine almost seems to fire with the kill switch off, I'm dropping the core cylinders to be bored of at the local engine guy tomorrow1557098362971736113609717786606.jpg
