Results 1 to 10 of 14
    May 2012
    pasadena
    Issues with solas prop maybe help?
    So i completely replaced and rebuilt my pump. i replaced everything with new. from axle shaft to housing. I put a solas concord 17/29 impeller in there but i dont know if i like it or not. It pulls hard low end. It will yank the ski out of the water and on plane hard but seems to hit rev limiter easily is that normal. Also Seems to hit hard and top out easy and i loose boost from hitting rev cut. i think thats normal too. Anyone else dislike the 17/29 prop ?
    Jun 2003
    JACKSONVILLE FL.
    Re: Issues with solas prop maybe help?
    I love mine. Did you check the impeller to stator clearance.
    Honda Pilot NAVI
    F150 4x4
    3 '06 F12Xs
    CR250
    2 CR80s
    1 XR100
    2 PW50s
    1 Vento Phantom 150
    1 Honda SHI 150
    Jax. Fl.
    May 2012
    pasadena
    yea it was like almost 0 paper thin I had all sorts of clearance with the orginal pump on there.
    Top Dog spatera's Avatar
    Jul 2006
    South Ga
    I lost a little top end also but was hell of a lot more fun getting there.
    03 Honda F12X (my favorite) Red of course
    Used to have:
    98 GP760, 97 GTX Sea Doo, 97 GP1200, 02 Honda F12X, 2-03 Honda F12X, 05 SeaDoo GTX Supercharged
    Need to have:
    F15X
    I dream skis jlfx car audio's Avatar
    Feb 2011
    jackson tn
    Chaos . this is on a 12x isn't it ? Sounds like the 29 isn't no where near 29deg u sure its not a prop for a 12 non turbo?
    Think they r like a 14/19 or something like that .
    The 14 is Ur launch but the 20+- is Ur top end .
    A stock ski with a 17/29 solus does have more punch but about same top end .
    I had one but repitched it many times to find the desired pitch I was looking for withy upgrades. (14/31 actual pitch not advertized pitch)
    04 Honda R12x modded with large IC,, large plentom, strait pipe , turbosmart fcd2, turbosmart mbc, wideband o2 gauge, vcs2 methanol injection, 14/31 prop (gps 68.2 )
    05 R12x w/ ic upgrade,strait pipe ,stock prop and boost 5380rpm @66.2mph
    May 2012
    pasadena
    no the non turbo pump is not the same as the turbo pump. But i think it was just the water. I toped out at 61.6 mph according to gps. I only have a solas 17/29 and a h20 extreme open exhaust. I think it was just a little goofy then. But it rides hard. only bummer is i fouled a plug today. They needed to be replaced anyways. Ive just been slacking on ordering them. Found them for 50 shipped for 4 on ebay. runs rough around 1-2500k but when im on it runs fine. but when close to idle it will miss.
    I dont know if i want to get the macboost module and an intercooler. I just dont know if i want to do anything else. I think its fast enough and reliable enough. I dont want to break anything. Its a fun ski.
    all R models have the same pump, turbo or non-turbo. The prop is different between them.
    Later, 05 and up F non turbos have a smaller diameter solas pump and solas prop from the factory. you could have a non turbo prop in your r.
    MACSBOOST!!! The Honda PWC Performance Experts. www.MacsBOOST.com
    Home of the MACSBOOST Module and the Fastest Honda PWC on the planet.
    http://www.youtube.com/watch?v=yqufmQ_8bxU
    Be our friend on facebook! http://www.facebook.com/pages/MACSBO...e/233077830901
    May 2012
    pasadena
    I dont have a R I have a F-12x and the pumps are different. The non turbo according to the manual is a bigger diameter pump
    Quote Originally Posted by chaos2984 View Post
    no, 03-04 na f models and all r na models use the same pump as all turbos.
    05+ f na use a solas pump and the diameter is smaller.
    May 2012
    pasadena
    oh ok
