Bodywork 101
Results 1 to 2 of 2
Thread: Bodywork 101
    Bodywork 101
    Seadoo hood repair, follow along as I go step by step repairing a broken Seadoo hood.
    Common Seadoo hood repair problem, kids ran the ski under the dock knocking a hole on the hood.It is also cracked clean through at the bottom left side.
    Re: Bodywork 101
    First we remove the hood, these newer models are fairly easy to remove, just remove the bolts in the center, the bolts at the hood release and the small 5.5mm screws, the pull the hood upwards, separate the hood and unhook the gauge.
    Next we grind the area from the back side with a grinding disc and cove the area from the top with duct tape.
