94 boston whaler rage engine conversion
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
    PWCToday Regular 1990superjet's Avatar
    May 2008
    coventry,RI,USA
    Wondering if anyone has any experience with these im picking up a mint 94 rage tm with the 650 engine in it, the engine isnt running but i think im going to tear it out anyway i have a 760 i just bought to put in a b1 but i would rather make it work in the whaler i dont know to much about these boats other than what ive read online, i know that the omc driven
    ones are terrible but the 650s are good just underpowered
    SE CT
    Re: 94 boston whaler rage engine conversion
    Sounds awesome. I've been looking for one of these. A 100 HP one would be sick
    R.I.P. Super Sic
    May 2008
    coventry,RI,USA
    dropped the 760 in had to modify a few things but its in if anyone knows anywhere or anyone who has parts for these boats lmk the steering cable was frozen and someone tried turning the bars until the steering box broke I rigged it up Td just to test out the boat but it won't last
    Jul 2011
    SoCal
    I just picked up the same boat last week. Far from mint condition but everything working less the reverse cable. I hope to get it in the water next week after fixing a little damage on the bottom of the hull. After a little goggling I found out about the same thing. Great little boat, just a bit underpowered with the stock 650 motor. I did take it to the scales after reading about the foam getting water logged on some early models. It came in at 1175 lbs boat, motor and trailer. Boat and motor should be about 800 lbs max. I don't know the weight of the trailer but I'm thinking 200-225 lbs max. Looks like mine has some water in the foam, will know a little better once I get the trailer weighed. Right now I just plan to play with it stock to see if I think its worth upgrading the motor this winter.
    May 2008
    coventry,RI,USA
    goes pretty good with the 760 i didnt get to drive it stock, had to change the coupler and the head but it dropped right in, it needs a prop but it did about 35 with 3 ppl, I found the teleflex steering box and cable last night on ebay for around 100 each,looked at the title last night and the boat is actually a 93, what does your boat have in it for a gas tank?
    May 2008
    coventry,RI,USA
    i also heard that these boats had a water leak issue but couldnt find where they leak
    Top Dog customride0105's Avatar
    Nov 2008
    sterling va
    Quote Originally Posted by AC 46 View Post
    I'm glad this tread came along... I don't have a Boston whaler but I got a jetncat. It's the 10ft version it's early 90s. Mine weighs 390 dry a build sheets to fallow but hears a teaser. Ac il beat ur 100 hp image.jpg image.jpgimage.jpg
    At least when my string hangs out I still ride...
    brad
    SE CT
    ^^^that's sick Brad..I was gonna say 150 but thought I'd catch some flak.
    R.I.P. Super Sic
    Nov 2008
    sterling va
    The Gf said if its painted pink w sparkles I can sell the big 4 stroke and she would hull my gas around for my skis
    brad
    May 2008
    coventry,RI,USA
    thats awesome ive never seen one of those, id like to put a tripple in the rage the hull would deff need some reinforcement i think,its just plywood with lag bolts that hold in the engine
