HELP!! 650 swap into a 550 - Page 6
Page 6 of 6 FirstFirst ... 456
Results 51 to 60 of 60
  1. #51
    JSX6550
    Guest
    Re: HELP!! 650 swap into a 550
    You Don't Need The 550 Couplers, I Kept The 550 One On The Driveshaft And The 650 One On The Motor, Works Fine In The 440/550 Format, Actually Moves The Motor Back Or Forward A Little, I Forgot Which, Performance Doesn't Suffer, I'll Soon Complete A Sx 650 Top Mated To A 550 Bottom, 650 Powered Of Course...
  2. #52
    Anchorage Alaska
    If i rember correctly they unscrew. But when you do your conversion your going to have to trim out your 550 pan. They say if you get the right conversion plate you dont have to do this and i have used a few brands now and i have had to do it with them all. The best way for all of it to fit together i have found, and some will argue, is by trimming the pan. I stayed with the 650 coupler welded up the pan ware the pan mounts to the ski, and grinded out ware the conversion plate bolts would hit the pan when the plate is mounted to the motor and then the plate. If you pre fit the motor plate and pan you wll see what im talking about. you can just throw the plate on there without grinding the clearence holes away bu this leads to an umproper fit on the coupler and you will tend to go through the little ruber coupler dampener about once a summer. also the stock 650 moors have a crankcase drain that you will either need to remover and plug up with a plate kit or cut a hole in the pan for it to clear. I left mine and cut a hole in the pan at abbout 1 1/2" in diamiter. Now afoer all this is done and the holes are welded up ware the pan mounts to the ski you will need to trim out the lip ware the batt is locatded at the rear of the motor.. mesure the holes and drill new ones. make sure to mesure the motor and use an extendable mirror to ensure that the couplers are meeting up evenly and strait. They i took off the oil injection to the 650 motor and baught a block off plate. You ca buy em on this website or e bay. the motor now will clear the gasstank and you ave a little mote room for that 650 exhast to squees in there. I stayed with the 550 water box and the 550 e box. Wiring diagrams are on this website that best explain how to rewire the motor into the hull. Also another problem you going to run into is that the throttle cable is going to be a little to short if you running a stock ( not a double carb)
    setup. You can have one made from a local cable making shop for under $50. Also i would reccomond going to a 17 degree prop and a top loader intake to boost low end and decrees cavitation in the pump. some mods you should look into is a aluminum CHARGING flywheel highcompression dual cooling head aftermarket pipe and intake. And mabey a little port matching. Do all the, wich is allot of work so prepaired to be dedicated and take your time, and you will have a pretty kick *** ski im on my third one now and there fun. And if you want to take it evean further bluprint the pump and move upto a 750 big pin motor using everything i have stated here!!!!
  3. #53
    Top Dog Kawi550Racer's Avatar
    Jun 2008
    Wisconsin
    why did you bring this post back you dumb ****
    working my way into a gp1300r. if you want to lend me some tips i would love the help
    JETSKIING. my antidrug....Welcome to the Addiction
  4. #54
    PWCToday.com Is My Home Away From Home the WaTeRhAwK's Avatar
    Dec 2004
    social relations specialist, adviser / consultant.
    lol!!!
    "I'm diggin' up bones.... I'm diggin' up bones........
    lmfao
    Quote Originally Posted by fastlife23, in regards to MrSki View Post
    Wow ive never seen a person ask the head of a profitable well known performance shop a question and then tell them what the answer should really be.?????? I am seriously dumbfounded.
    CCC
  5. #55
    Resident Guru Dpeteland's Avatar
    May 2009
    B.F.E. Arizona
    Quote Originally Posted by JSX6550 View Post
    just wow... making a franken stien arent u?
    im doing this 650 conversion to my 550sx *threads on greenhulk.net*
    http://www.greenhulk.net/forums/show...t=91277&page=4
    -Pete
    Quote Originally Posted by sxr951 View Post
    standups suk monkey azz! VIVA la jammer!!!
    Ran with that chopped up aluminum prop? That's pretty much a waste of time. I understand wanting to go for a run but that's like running down the 1/4 mile with the parking brake on.
    -unknown
    Robot Pirate Ninjas (RPN) - United
    Sasquatch Gang
    Man Bear Pigs Alliance too.
  6. #56
    Frequent Poster skiman650's Avatar
    Apr 2009
    Rhode Island
    will a 440 electrical box work with a 650 motor if i swap the regulators?
  7. #57
    May 2009
    B.F.E. Arizona
    Quote Originally Posted by skiman650 View Post
    ive seen it done... but you are much safer using a 650 cdi ..... and in all my tests... the 440 or 550 ignition coil has an electrical impedence not matching that of a 650. therefore no spark...
    i can get you the wiring diagram i got from jet world powersports from the owner.... didnt seem to help me much.
    but if you need a plate or help with a plate i got those!
    -Pete
    -unknown
    Sasquatch Gang
  8. #58
    Top Dog 84kawi550's Avatar
    Jul 2009
    New Haven, CT
    Quote Originally Posted by Pete Jacobs View Post
    I would take a guess at the 550 being around 43 hp and the 650 53 hp. I think I am erring on the conservative side. A 440 is 35 I thought. OR was the 300, 35 and the 440, 33 I always heard stock 300's could beat stock 440's.
    the 550 was 39 hp, the 440 was 27, and the 300 was 30. as far as i know.
    the 300 cant beat a 440. the 300 makes all its power at peak RPM, whereas the lower revving 440 has more torque at a lower RPM.
    Jeep, Arctic Cat, and Kawasaki, just about sums it up.
    Co-founder of the First Church Of Internal Combustion.
    '84 JS550, 1mm reed motor, PJS half pipe, SBN44, skat 15
    '92 750sx, custom curved connecting rod.
  9. #59
    May 2009
    B.F.E. Arizona
    Quote Originally Posted by 84kawi550 View Post
    very well put... same goes for a 550 rpm at bottom and top end vs. a 650.... the rpms are much higher... yet the engine on a 650 is much bigger and will go faster because it has more power...
    remember that not always does rpm = power... i can get a tiny electric motor to pump out 60k rpms... and still yet get another the same size... to push out low rpm but much more strength and torque ... but it will not be able to spin very fast.
    -Pete
    -unknown
    Sasquatch Gang
  10. #60
    Nov 2012
    Lakewood
    Quote Originally Posted by Art_Maybee View Post
    here is the diagram to run the 550 electronics with the 650 stator.
    where is the diagram?
