Monster Motorsports XIR1100 - Page 2
Results 11 to 20 of 30
    Resident Guru jdakrt's Avatar
    Mar 2006
    Chesterfield VA
    Re: Monster Motorsports XIR1100
    Quote Originally Posted by HX RACER View Post
    What's involved in dropping one of these 1100's in a XIR? Is it a drop in mod, what bedplate & shaft are you using? Im getting a hull from a friend in a couple weeks.
    Glass work. Basically extended the stringers to bolt in the 1100. 1100 bedplate, 6 550 style motor mounts (these team hulls are a bit different from the production units). xir shaft. There is no room to move the motor rearward, as the coupler is basically at the bulkhead. 760 yamaha waterbox fits like it was meant to be there, and the chamber water jacket has to be cut out and welded up where it hits the footwell (see the thread in this section), or you can glass a bubble in the footwell.
    "PITD" proud member of
    Team TFP
    I dream skis HX RACER's Avatar
    Feb 2010
    PSL Florida
    Awesome, this is going to be a winter project!
    PWCToday.com Is My Home Away From Home kawi66's Avatar
    Jan 2003
    kawiland
    I may end up selling the carbon xir hull, you can use a 800 or 1100 motor in it.I really want to focus on the farthing x-4 hull.i have way too much money tied up in ski's right now!
    it's a blast to ride probably around 62mph with a 1100 in it,if you watch the video scottie posted under spec runabout racing you will see my zxi barely outran it to the first turn.
    1997 team Kawasaki carbon zxi 1100
    1997 atm lightweight zxi 1100
    Feb 2010
    PSL Florida
    I used to have a x4 800 limited. I loved the way it handled but I hated the doo motor. How will a 1100 xir compare?
    Jan 2003
    kawiland
    it will not handle like a x4 hull......with this much power it is a bit of a handful to say the least.
    Feb 2010
    PSL Florida
    Is it worth the trouble of doing the swap? Are you happy with the end result? I'm super excited about getting this XIR Hull. If I'm gonna get a motor I was thinking I might as well get a 1100 instead of a 750...
    I dream skis NorCalGSX's Avatar
    Jan 2008
    Sac-a-tomato
    Dang, I would love to throw my name in the hat for this hull also.
    That Farthing Hull is bad-arse, it has to be superior to Xir just due to research put into that hull. I think the comfort level in the x4 hull at high speed also has to do with how you are positioned behind bars vs pretty much looking over them. And the hull footprint on the water. Xir feels like you are riding a pencil and the X4 more like a bigger pen. If that makes sense.
    Jan 2003
    kawiland
    Makes perfect sense if you have ridden both!..........I think with some handling mods the xir would do fine. it likes to be turned flat and i am used to a lean in hull(hx)......I like the seating position of the zxi better.I started out racing zxi's and so i just like that hull.
    Can't wait to finish the farthing hull.our other 1100 x4 is a blast to ride......
    Jan 2003
    kawiland
    SOLD!...........going back to cali,cali,cali...................
    Oct 2009
    Jersey Shore
    Glad I had the opportunity to throw a leg over that thing! New owner will be very happy.
