sn sj not turning over
    Mar 2013
    fort walton beach
    i have a 92 sn sj that was running great two days ago. got it home flushed it out everything was fine. went to take her out yesterday and it turns over runs for about 3 seconds then dies. when i go to give it gas it bogs down. i replaced the plugs and found they were pretty nasty. so i put new ones in and it fired up and ran then died and continued to do the same problem. my fuel lines have given me trouble in the past. not having pressure or being lose. any clues to why it would run for a few seconds then die?? thanks!
    PWCToday Guru extreemthrottle's Avatar
    palm beach county, fl.
    Re: sn sj not turning over
    does it have choke or primer on it?
    providing new and used parts & service to the pwc community for over 10 years.
    check out our feedback and buy with confidence!
    PLEASE check out our facebook page and like us for updates and specials!
    http://www.facebook.com/pages/Extree...50813671626944
    We carry ADA, Blowsion, Solas, Protec, R&D,Thrust, Watercross of texas, RHAAS Products and more!
    WE OFFER FULL MACHINE SHOP SERVICES!
    please pm us with your needs or email at extreemthrottle@yahoo.com.
    www.extreemthrottle.com
    Jul 2010
    Near yosemite
    Check the easy stuff first....sufficient fuel supply? Do you have a selector? Fuel filters plugged? The I would move on to checking if it will stay running with manually providing fuel via primer or other method. If so its time to inspect the carb for thorough cleaning and rebuild
    Mar 2013
    fort walton beach
    has a full tnak of gas. yes the selector is on "on" and it has a new fuel filter. when i pulled the plugs they had like mud on em.my friend was saying to get some fogging oil and clean it out that way if not im gonna have to pull the carbs and clean em im new to two strokes so im still learning.
    Mar 2013
    fort walton beach
    and the choke isnt even connected to the fuel line anymore. one problem i have had in the past was the lose fuel lines. where they connect to the selector they are lose. so i know i lose pressure in the lines and thats caused problems before as well, its hard to get a zip tie up there to tighten em down and for it to stay tight
    take the ebox off and remove the fuel selector. its a simple job. if you dont go far enough to use reserve often i'd bypass the selector all together. less problems down the road.
    Resident Guru runrider's Avatar
    Jul 2010
    PA
    How long has it been since you gave the carb a good cleaning?
