Results 1 to 6 of 6
    Top Dog javiert99's Avatar
    Aug 2004
    Jupiter, FL
    How hot does the exhaust pipe get?
    I don't remember *exactly* how the starter wiring was routed, as well as the exhaust temp sensor, so I was just curious as to how hot that exhaust pipe gets and if I should be extremely concerned about things not being able to bump into it, touch it, and get burned.
    I've got everything in, but want to make sure before I bolt it all down.
    1997 Seadoo SPX - stock 787 - FOR SALE
    PWCToday.com Is My Home Away From Home ph2ocraft's Avatar
    Sep 2002
    Campbell, California
    The pipe is water cooled, therefore unless something goes wrong the pipe is fairly cool. Think about this..............the temperature warning switch is mounted into the exhaust manifold how??
    Did I get that right?? It is in rubber isn't it?? Geesh, now I can't remember.
    Either way it's not good to have any wires touching any objects unless securely fastened as not to allow schaffing or cuttung of the wires.
    resident guru TxPro1200's Avatar
    Feb 2004
    tejas
    pipe
    the pipes not hot enough to be a concern,and the temp sensor is mounted with rubber
    2000 pro 1200 69.1 gps
    2000 virage tx 67.8 gps
    2000 virage tx 62.3 gps
    Apr 2004
    Tampa, FL
    Doesn't the stator wire loom go under the engine plate to the carb side of the engine? Between it and the hull?
    Sep 2002
    I routed the wires for the stator to the wiring loom on the hull and then ran it back to the box where I installed water proof connectors for easy removal/testing next time it's needed.
    Feb 2004
    tejas
    wires
    yes it does,on a single pipe ski,i route it foward of the front mount,then between the two hull mounts,and outside of the right rear hull mount
