"Clean" build - Page 3
Results 21 to 30 of 39
Thread: "Clean" build
    PWCToday Guru vega's Avatar
    Oct 2011
    Montana
    Re: "Clean" build
    Good, glad to hear you got it to loosen. I've gotten a lot of stubborn bolts loose with a long enough breaker bar. Gentle force, with enough leverage should usually get the job done. Like you said, patience works.
    Jul 2012
    syracuse
    Re: "Clean" build
    new to me 9/17 prop on its way. just repitched and lookin goodimpeller.jpg
    "No cops in sight = Permit"
    Top Dog w650gb500's Avatar
    Jul 2009
    northeastern PA
    Re: "Clean" build
    What did that prop cost? If you did have to pay for it, why not go with some modern prop technology and get a big hub swirl set-up?
    Dan Lipperini Jr
    www.RaceLabz.com
    Jul 2012
    syracuse
    Re: "Clean" build
    I bought it used and repitched for 120 shipped I was told by many people its a good prop for a mild modded x2
    Jul 2009
    northeastern PA
    Re: "Clean" build
    When people are telling you to get a 9/17, most will mean a big hub swirl set-up which will act considerably different than a standard hub. IMO, there is no comparison between the two. Try it and see how it works, but when the weather breaks, I would tell you to also try a big hub and see for yourself.
    Dan Lipperini Jr
    www.RaceLabz.com
    PWCToday.com Is My Home Away From Home WB1994's Avatar
    Jun 2005
    New Hampshire
    Re: "Clean" build
    The old 9/17's are poop in my opinion.
    Sep 2010
    syracuse NY
    Re: "Clean" build
    told you!
    89 rockerd X2, ported and polished 65 SOLD
    93 waveblaster 701 SOLD
    Fix'd steer 650sx ​SOLD
    100% custom X2 project
    Originally Posted by JonnyX2
    One kick is maintenance....twice is abuse
    Jul 2012
    syracuse
    Re: "Clean" build
    got my prop in today. just need to get the old one out now... been dreading this.
  9. #29
    Jul 2012
    syracuse
    Re: "Clean" build
    got the old prop out rather easily, im upgrading to dual cooling, so i can run independant lines. One line for the motor, and one line for the headpipe. this way i can tell right where the problem is by which pisser isnt flowing, and i get better cooling overall. I bought 2 .5X36" aluminum pipes to replace the plastic tubes in the hull i also bought 2 3/8 ID adaptors to tap into the pump. im upgrading the size of the factory one and adding a second across from it. This should solve my cooling issue that kept me from riding last season. I couldnt find 90* adaptors at the local hardware stores so im using straight adaptors and making the turn with the hose instead. hopefully this gives me sufficient cooling to stop the overheating problem
  10. #30
    Jul 2012
    syracuse
    Re: "Clean" build
    cooling 1.jpgcooling 2.jpg this should give me noticably better cooling!
